Suspension identical SR versus ER?
Ajjra
New York
F-150 Lightning Lariat
Do the standard range and extended range Lariat models have identical suspension components or are the dampers and/or spring rates changed to accommodate any differences?
sotek2345
Engineering Manager
As far as I know they are the same. Both have the same GVWR, to SR trims just get more cargo capacity, so no reason for them to be different.
Yellow Buddy
Smart Ass
I haven't ripped them apart but my Pro SR and Lariat ER appear to have the same suspension components.
That said...the Pro SR rides better than the Lariat ER. The Pro rides like an old school caddy, it's soft and floats like a boat. The Lariat isn't harsh but you definitely feel the road more. Some of it is due to the wheel/tire combo as well but that weight is noticeable on the suspension.
Ajjra
Ajjra
New York
if you ever put 18 inch wheels on your lariat ER please let us know how the ride is. I’m curious how much of a difference you’re feeling is the wheel and tire combo and how much of it is the extra weight. My suspicion is that it’s the wheels and tires more than the weight difference.
FordLightningMan
Upstate New York
F150
I imagine it's 90% wheels/tires and 10% weight. When I do the swap from 18 inch snow tires to 20 inch summer tires on my car, it drives like a completely different vehicle.
I'm guessing someone on the forum is doing a winter to summer swap on the Lightning, maybe we'll see someone comment to confirm.
Replika
United States
MR. PLOW - ER Lariat
I agree with this. The Pro felt a lot softer to me than my ER, and I think better over bumps. The weight difference is noticeable. It's around 700 lbs IIRC.
Yellow Buddy
Smart Ass
It's possible but keep in mind the 18s are on All Terrains while the 20s are all seasons. So it's also possible the tire stiffness cancels out the extra rubber. The difference from the 22 Platinum Wheels to the 20s were also noticeable though.
I know on the Rivian the 22s (High Perf. All Season) ride harsher than the 21s (All Season) but the 22s ride about the same as the 20s (All Terrain).
I'll have to run the same test on the Lightning as well.
I have to dig up my CAT weight slip. I think it was almost a 900lb difference on the scales.
It was almost amusing as the cheapest one was the more "luxurious" in terms of ride quality and noise isolation. I'm not sure what else it could be but my guess is that between the moonroof, the rear window, the Lariat ends up with more noise than the Pro.
sotek2345
Engineering Manager
True on the A/T tires, but the factory A/Ts on the Lightning are REALLY weak / light duty A/Ts. I wouldn't expect that much stiffness difference.
Replika
United States
Yeah, I drove a very stripped down Pro, a Lariat SR, and purchased a Lariat ER.
The Pro (sans moonroof) was the quietest, both in terms of wind and noise over bumpy roads. It felt the most isolated. Also the best ride as we've said. I think Edmunds also mentioned the ride quality being better in SR.
I replaced Platinum all-seasons with Lariat ATs and noticed zero difference. Maybe the test instrument wasn't precise enough.?‍♂
For sure with the big glass roof alone.
Also, every different tire size and type will give a different ride. I'm looking at next winter for some 18's but I might just go with the 20's, I don't want to lose more range in the winter.
Yellow Buddy
Smart Ass
I think it’s the size vs compound. You probably lost flex with the ATs, but gained flex with the larger sidewall. Net 0 difference.
BzzzzztZapPow
21 Explorer Hybrid, 18 Fusion Hybrid, 22 Lightning
I'm not sure a butt recalibration is readily available or what that would look like.:ROFLMAO:
Maybe I'll put the 22s on the left and the 20s on the right and see if I notice a difference. Or maybe front and back.?
