I haven't ripped them apart but my Pro SR and Lariat ER appear to have the same suspension components.Do the standard range and extended range Lariat models have identical suspension components or are the dampers and/or spring rates changed to accommodate any differences?
if you ever put 18 inch wheels on your lariat ER please let us know how the ride is. I’m curious how much of a difference you’re feeling is the wheel and tire combo and how much of it is the extra weight. My suspicion is that it’s the wheels and tires more than the weight difference.I haven't ripped them apart but my Pro SR and Lariat ER appear to have the same suspension components.
That said...the Pro SR rides better than the Lariat ER. The Pro rides like an old school caddy, it's soft and floats like a boat. The Lariat isn't harsh but you definitely feel the road more. Some of it is due to the wheel/tire combo as well but that weight is noticeable on the suspension.
I imagine it's 90% wheels/tires and 10% weight. When I do the swap from 18 inch snow tires to 20 inch summer tires on my car, it drives like a completely different vehicle.if you ever put 18 inch wheels on your lariat ER please let us know how the ride is. I’m curious how much of a difference you’re feeling is the wheel and tire combo and how much of it is the extra weight. My suspicion is that it’s the wheels and tires more than the weight difference.
I agree with this. The Pro felt a lot softer to me than my ER, and I think better over bumps. The weight difference is noticeable. It's around 700 lbs IIRC.I haven't ripped them apart but my Pro SR and Lariat ER appear to have the same suspension components.
It's possible but keep in mind the 18s are on All Terrains while the 20s are all seasons. So it's also possible the tire stiffness cancels out the extra rubber. The difference from the 22 Platinum Wheels to the 20s were also noticeable though.if you ever put 18 inch wheels on your lariat ER please let us know how the ride is. I’m curious how much of a difference you’re feeling is the wheel and tire combo and how much of it is the extra weight. My suspicion is that it’s the wheels and tires more than the weight difference.
I have to dig up my CAT weight slip. I think it was almost a 900lb difference on the scales.I agree with this. The Pro felt a lot softer to me than my ER, and I think better over bumps. The weight difference is noticeable. It's around 700 lbs IIRC.
True on the A/T tires, but the factory A/Ts on the Lightning are REALLY weak / light duty A/Ts. I wouldn't expect that much stiffness difference.It's possible but keep in mind the 18s are on All Terrains while the 20s are all seasons. So it's also possible the tire stiffness cancels out the extra rubber. The difference from the 22 Platinum Wheels to the 20s were also noticeable though.
I know on the Rivian the 22s (High Perf. All Season) ride harsher than the 21s (All Season) but the 22s ride about the same as the 20s (All Terrain).
I'll have to run the same test on the Lightning as well.
It was almost amusing as the cheapest one was the more "luxurious" in terms of ride quality and noise isolation. I'm not sure what else it could be but my guess is that between the moonroof, the rear window, the Lariat ends up with more noise than the Pro.
Yeah, I drove a very stripped down Pro, a Lariat SR, and purchased a Lariat ER.I have to dig up my CAT weight slip. I think it was almost a 900lb difference on the scales.
For sure with the big glass roof alone.Lariat ends up with more noise than the Pro.
I think it’s the size vs compound. You probably lost flex with the ATs, but gained flex with the larger sidewall. Net 0 difference.I replaced Platinum all-seasons with Lariat ATs and noticed zero difference. Maybe the test instrument wasn't precise enough.?‍![]()
I'm not sure a butt recalibration is readily available or what that would look like.I replaced Platinum all-seasons with Lariat ATs and noticed zero difference. Maybe the test instrument wasn't precise enough.?‍![]()
Maybe I'll put the 22s on the left and the 20s on the right and see if I notice a difference. Or maybe front and back.?I think it’s the size vs compound. You probably lost flex with the ATs, but gained flex with the larger sidewall. Net 0 difference.
