Sync 4a Bug: 24 Hour Time
artificial_airspeed
Fort Worth, Texas
2022 Ford F-150 Lightning | Lariat SR
Has anyone else noticed if you have 24 hour time enabled in your General Settings, the next key cycle the displayed time will go back to AM/PM format even though the 24 Hour Time setting shows enabled still….. Small bug, but kind of a silly one. Basic UAT/QC during the software update cycles seems non existent.
Nick503955
Nick
San Diego, CA
2023 Ford Lightning Lariat, 2024 Kia EV9
Yes, I noticed the same issue. Not sure if it is still the case with the updated interface.
Ford Motor Company
Official Ford Account
F-150 Lightning
Hi there. Will you send us a message with your VIN and dealership name/location? I can look into things on my end.
Ford Motor Company
F-150 Lightning
Hey! I can take a closer look into your clock hour format concern if you like. Can you send us a direct message with your VIN and the dealership name/location?
Nick503955
Nick
San Diego, CA
I just checked now that it is after noon, and the clock shows in 24 hour time. It seems the last update fixed it. Thanks for following up.
DucMan
Scott
‘22 Lightning Lariat ER
I’m on 4.2.4, I still have the problem. It might show 24 hour clock has been selected (if I look at the clock settings) but it will display 12 hour clock.
ford knows, they told me it will get fixed in a future update.
scott
Mike G
N. AL, USA
So a couple of months ago I noticed this on both my Lightning and Mach-E and they both did the same thing. I would set the time format to 24hr and the next key cycle it would revert back to 12hr...but when I went to reset it to 24Hr...the button showed it was already set to 24hr in the settings. So I would turn it back to 12Hr and then once again set it to 24Hr and it would then change the time format back to show the desired 24hr format.
I had to do this like twice over two days but now it does show the 24Hr format consistently.
I don't know the reason it wasn't initially "sticking" to 24hr format, but after changing it like twice over two days both my vehicles have now settled and are displaying properly.
I'll try this and see if mine will finally stick.
