Charging question.
TerryNelsen
Terry
Ca
F150 lightning SSV package
My truck charged at 22kwh before ford replaced the front motor, know since I have had it back it charges at 11kwh. 2023 xlt SR 9.6 kwh system. Any ideas?
Ford F-150 Lightning Charging question. 1692219522418
Seriously, what are you using to charge the truck?
Also, kWh is a quantity of energy. kW is the rate. For instance, the FCSP can charge at 19kW which over the course of one hour is 19kWh. 22kW isn't possible on level 2 chargers that I'm aware of. What are you using to determine the charge rates?
TerryNelsen
TerryNelsen
Terry
Ca
My mistake it's 22kw is the rate my charger is capable of.
TerryNelsen
TerryNelsen
Terry
Ca
My n charger b is a primecom tech 80 amp charger that requires a 2 pole 100 amp breaker.
TerryNelsen
TerryNelsen
Terry
Ca
jerock
Jerry
Kansas
That would be 91.6 amps at 240 volt. I think someone mislead you.
22kW / 80A = 275V
Is that possible in a residential home? I looked up the website, very misleading to promote that it can do up to 22kW.
And Rick is correct, the truck's onboard charger for charging the truck is a separate piece of equipment than the ProPower inverter. I hope it wasn't the dealership that told you that.
22kW / 80A = 275V
The maximum voltage the utility can supply and still be adhering to ANSI specs is 253V.
Edit - this is for a 240V system. Utilities can supply systems with higher utilization voltages (480V, for example).
@tommolog Do you know anything about this company? (PrimecomTech)
tommolog
New Jersey
www.youtube.com
2022 F-150 Lightning Lariat, 2023 Rivian R1S, 2024 Chevrolet Equinox EV
Journalist
I haven't done a full review of thier products yet, but I have seen and used them. I from my limited experience I'd say they are average to slightly below average as far as build quality.
