Avocadodude
Kurt
Fallbrook, CA
F150 Lariat
Ok I’ve had the shocks on a couple days now. They are fantastic and what I was hoping for. I went with a 1 inch lift in the front and kept the rear at stock height. However, it does appear the rear is a tad lower than before, maybe half inch lower in rear wheel well to tire distance. The dreaded old bed bounce is gone in the front. The only real con is you feel the small bumps on the road a bit more. But everything else feels better. Turning, off-roading, hitting curbs: all super plush now. There is a little whooped out trail near my house and I can go twice as fast now. Amazing. Just so much sportier and confidence inspiring now. Can’t wait to tow my trailer and rip around in the desert. Thank you Eibach!
I know that truck, drive past your truck almost everyday ?. I was admiring the new tires (well I just started paying attention to tires on Lightnings since I’m due soon), almost stopped and knocked to see how you liked them.
T i h o r
Rohit
Toronto
Self Employed
I actually use it quite often during harvest (avocado, grapes) I mean it would ruin me to lose it, but very convenient functionality.
Thanks for sharing! I couldn't really think of many use cases, but yours definitely makes sense.
I leveled my truck with a 2" lift (puck) in the front, and I'm curious now if the scales still work.
MontanaLightning
Montana
2023 Ford F-150 Lightning
Ford says the scales are only accurate to within 200 pounds. That's good enough for you?
Avocadodude
Kurt
Fallbrook, CA
F150 Lariat
Yep. I find them much more accurate than that though. Really it's just for knowing if a bin is close to 800 lbs. I can do it mostly by sight, but you'd be surprised what is hidden in the bottom of a bin when you're not looking. Also a daily reminder of how fat I'm getting. Maybe new shocks will make me think I've lost 40 lbs ?. The ride quality on grove roads might outweigh scales functionality.
ninjaybot
ninjaybot
CA
22 Lightning Lariat
Love the tires. But I am going to try the new EV versions when the time comes.
surlymcm
SC
23 Lariat ER order. 23 Taycan 4CT, 04 E 320 wagon
That looks great. Ordering today. What size are those tires? Thanks!
SmoothJ
New Jersey
2022 F150 Lightning
Damn, that's wild. So I mean I know the platinums have or at least had massage seats with lay flat functionality, but do we know what else is that much heavier inside the cab? More sound deadening or something?
Most likely the stuff that you said, plus speakers, sunroof, etc.
ctuan13
Chuck
Pittsburgh, PA
Well Lariats also have the sunroof. I mean you're probably right, it's just hard to imagine all that other stuff weighs that much more.
Yellow Buddy
Smart Ass
Does anyone actually need their scales, or is it more of a cool feature to have. So many times I've had the truck loaded, and remember I should have checked the weight only after I've unloaded. Not that I need to know, but just for the novelty of it.
Personally, losing scales would be a small price to pay for a lowered Lighting!
This. I loved the selling point. Hate the actual usage.
I’m supposed to calibrate it before I load vs just hopping in and pulling it up. Seems silly and losing the scales is meh to me.
Yellow Buddy
Smart Ass
Yes.
Front Coil:
PRO/XLT/Lariat
Wire Dia (Inches): 0.73
Rate (lb./in.): 543
Platinum
Wire Dia (Inches): 0.75
Rate (lb./in.): 600
Rear Coil:
PRO/XLT/Lariat
Wire Dia (Inches): 0.69
Rate (lb./in.): 251
Platinum
Wire Dia (Inches): 0.70
Rate (lb./in.): 280
Source:
https://www.f150gen14.com/forum/downloads/2022 F-150 Lightning eSourceBook.pdf
I wonder if the actual difference is the unsprung weight vs the spring weight.
IIRC (and I may not be) my loaded Lariat is closer in weight to a Platinum than it is to a SR Pro. It wouldn’t make sense to distinguish between trims but not battery size.
I wonder if they increased the spring rate to control the heavier 22” wheel.
Also interesting to note that the curb height of the springs are higher on the Pro and the Platinum than the XLT and Lariats. Does that mean they ride higher too? Wonder if that ties to the efficiency as the Pro and the Platinum gets worse efficiency numbers…
thedadlegend
Stephen
TX
Smoked Quartz Lariat ER
@ninjaybot so you ordered front and rear shocks, but no springs? And what did you have done specifically? I'm trying to get quotes for this work but want to make sure I ask for the right thing.
Zeus SR
Chilliwack
2023 Ford Lightning Pro SR
I am so excited for the lowering springs! Will definitely get them along with the shocks that are already out, a nice 1” front and 2” rear lowering would be perfect, and a tighter handling ride would be great. I’ve been driving a 2010 Infiniti G37X coupe for the last year and a 2012 Cadillac CTS4 Sport Wagon for 3 years before that, so have gotten very used to firm and well-handling suspensions. My SR Pro drives beautifully but definitely leaves room for improvement in handling! Fingers crossed Eibach solves this for us
ninjaybot
ninjaybot
CA
22 Lightning Lariat
Correct just the shocks. The shocks have notches for the c-clip that holds the plate the springs rest on. You’re able to get 0 to almost 3 inches in the front and 0 to 1 in the rear. They ran it up as replacing shocks for 4 coil overs and an alignment.
