artificial_airspeed
Fort Worth, Texas
2022 Ford F-150 Lightning | Lariat SR
Are FDRS servers down? I've tried to login for the last 4 days and get the "cannot reach FDRS servers" error. Yet when I check my connection everything is PASS and green. ?????
I don't have access to FDRS, but I'm going to go out on a limb and say they are not down. @rugedraw has had access and posted updates from FDRS from others wanting an update on their truck. It appears to be working.
I was using PTS. I do have fdrs access, but not home now to check.
Andrewbens
Modesto
Lightning
Mechanic
I don't have access to FDRS at the time, but this is what PTS is showing pending for you:
Anything pending for my Truck? Currently at the dealer trying to get them to install at least the Tesla update.
Vin 1FT6W1EV2PWG25879
Here's your list, but good luck getting them to update anything.
Ford F-150 Lightning Lightning Software Updates using FDRS 1712681581046-ji
Andrewbens
Modesto
Lightning
Mechanic
how would I go about it to get them to update it all? Is it really that hard to update things
LazyLightningATX
Doug
Austin
'23 Lariat ER
You can just try pestering them to do it, but the thing is some of those modules can take a really long time to update and if you have a bunch, it can practically take all day. I think this is one of the big reasons they won't do it.
Andrewbens
Modesto
Lightning
Mechanic
gotcha, all they do is gotta click update and walk away right? And just go through the steps.
LazyLightningATX
Doug
Austin
'23 Lariat ER
Eh, in my experience it seems to need a bit of babysitting, every module has to be done individually...some of the modules require power cycles... I had one seem to fail and just kept cycling through for hours and I finally had to sort of hard crash FDRS to get it to stop. That turned out ok, it had installed but was failing some sort of check...so, not quite set it and forget it!
Andrewbens
Modesto
Lightning
Mechanic
Sounds like a pain. Is there anyway to get ahold of this programming for a normal person?
LazyLightningATX
Doug
Austin
'23 Lariat ER
Andrewbens
Modesto
Lightning
Mechanic
I believe there is someone, may be more than one person, on here that sort of has a loaner program for them...
I do. I have two of them. The waiting is list is weeks long at this point, but I can add anyone that wants to borrow one to it.
@Andrewbens If you're interested, PM me and I'll send you the link to the thread. I have posted it here before and it gets deleted.
dugiepts66
Doug
Oakland, CA
'23 F150 Lightning Lariat ER- Azure
Tech
Alright lightning team, could use some help. I’ve got the mongoose, and having trouble trying to install the sw and drivers into a virtual windows 11 machine in my MacBook Pro. Have any of you done this…and/or do you know for a fact a virtual machine just won’t work?
Have used virtual machines plenty in the past, but can see windows 11 isn’t recognizing the device correctly after installing the software suite.
Thanks for any help.
