Fordpass app won't let me set charge target limit.
Lightning Rod
North Coast
2023 Ford Lightning Lariat ER
CNC PROGRAMMER/MACHINIST
During the weekdays, I set my Ford Charge station pro to charge truck to 70 percent and Friday night after plugging in, I will set charge limit to 80 or 85 percent. I've looked all over this app but the settings for the charger will not appear. Maybe I'm missing something. I'm looking at the charge session page and it says that the target charge level is 100 percent but I don't want 100, but there doesn't seem to be any other options for setting target limit. Weird. :unsure:
The "Use preferred charge settings" bullet should be active, tap it to adjust the factors.
Ford F-150 Lightning Fordpass app won't let me set charge target limit. 1714794107481-v1
Make sure your time frames are set correctly for weekday & weekend.
Slide right/left to toggle between weekdays and weekends.
Make sure the SOC you desire has been adjusted to your higher weekend requirement, note you will need to lower this for your weekday routines.
Ford F-150 Lightning Fordpass app won't let me set charge target limit. 1714794048681-4f
Note these changes may not reflect on the [charging session] panel when a charging session is active, but rest assured they will be the next time you plug in.
Ford F-150 Lightning Fordpass app won't let me set charge target limit. 1714794701810-jy
Finally, if the Ford Pass app is uncooperative, then make the changes on the CHARGING app in the trucks Sync screen, make these changes BEFORE plugging in.
Lightning Rod
Lightning Rod
North Coast
Ok, this was my problem. I went and unplugged the truck and set limit in truck display. I plugged it back in and it then worked like normal... showing the settings link. The truck was at the dealer earlier and maybe they reset something.
Thanks again, TaxmanHog for you expert Lightning Truck advice! :clap:
davehu
hot springs, AR
...what he said!
snowy_91
James
Aurora, SD
2023 Lightning XLT SR, 2024 Blazer EV
Was not working for me last night ether, but it's working today.
astolleis
Alan
2022 F150 Atlas Blue Lighting
I'm using the FordPass app on an iPhone13 and have been fighting a similar issue after a large trip. I want the truck to charge between Midnight to 6am to take advantage of a 4.1 cent rate with my provider.
I have been fighting the issue for the past week. The only message I was getting was FordPass was not available when trying to save my settings. It didn't matter how I approached the issue on the Phone. If I used the Panel in the truck it wanted to start charging immediately.
I finally solved my issue, I logged out of the Ford Pass App, Deleted the App after being warned associated data would also be deleted. Downloaded the App from the AppStore. I logged in again. My previous charge settings were back and could be changed. All the other data like planned trips, charge logs all came back down. Assumption - Either latestest iOS patch or download of a Ford Pass update from Apple AppStore caused a corpution of the Ford Pass data on the phone.
CavRider
Somewhere near Minneapolis
F-150 Lightning, BMW i4 e40, Kia EV9, Ford Expedition
+1 Easy peasy fix. Took less than one minute. iPhone 14 Pro, iOS 17.4.1
