Adding safety strobe functionality to Lightning?
Avocadodude
Kurt
Fallbrook, CA
F150 Lariat
Has anyone added strobe functionality to their Lightning? I may wind up just adding extra safety lights, but wanted to see if anyone has tried anything with existing lights.
mikeyb
GA
2023 F150 Lightning
2-years later, sorry from another Fallbrook guy, I just added a GREAT kit! About $380 including fast shipping. Took 27.5 min to install including fighting with the Ford trim. Great flashing all around (see my poor video). Can use dimmer handle to activate/deactivate. Bad news, Lightning is new, so I got the module without the software update, no notice it needed the update, poor flashing in the 3 modes. Great tech support to find out how to (easily) update adding a 4th flash mode just for the Lightning.
Avocadodude
Avocadodude
Kurt
Fallbrook, CA
F150 Lariat
What kit is it?
Avocadodude
Avocadodude
Kurt
Fallbrook, CA
F150 Lariat
Azgunguy
Michael
Northern Arizona
2023 Lightning Pro and 2012 Expedition Fleet
So do all the lights flash? Im trying to figure out what’s flashing and what’s just the LEDs messing with the cameras frame rate. But it looks great!
mikeyb
GA
2023 F150 Lightning
All lights were off when I activated the strobe system. So anything you see on was energized by the strobe system.
Yes, some light appear to be flickering in the video, such as brake lights, they really are flashing not flickering.
Henryw
Henry
South Elgin, IL
2023 Ford Lightning, Lariat Ford Flex
Motor Coach Logistics
I’ve been curious about this kit myself. Thanks for posting! Have you had any issues after installing the kit?
Runaway Tractor
Yes
I want something like this too, but I am very picky. Also very much don't want to piss off the state police. I messaged to ask if their kit could be configured to only flash specific lights that I want to flash and the answer was unfortunately no, it is all or nothing with that system. There's some other similar products that use individual modules for specific lights. Just haven't had time to get into then yet.
Ish
‘23 Lariat ER
I installed green/amber LEDs on the front windshield and green/amber and red/amber on the rear glass plus an amber safety director. Don’t need them frequently but I am out on projects or scenes occasionally and any additional flashing lights do help.
All within the cab and went with a system that can be hard wired or run through the 12v cig outlets. Not a ton of room behind the rear headrests to work with but it works.
mikeyb
GA
2023 F150 Lightning
None. Works great. I didn't use the switch, I stuck with the headlight lever to activate/deactivate.
DCAZEV
Phoenix, AZ
2023 F-150 Lightning Lariat ER / Avalanche / Max Tow /
Self Employed
I'm in the same boat with you. I just want the front headlights to flash, not all of the turn signals and the stuff to the rear. Not sure if any company has come out with a solution. I called the Z-Flash company and they told me that there is no way to just flash the headlights without flashing the front turn signals.
DCAZEV
Phoenix, AZ
Self Employed
Iirc with a simple forscan change and grounding one wire you can get the headlights (and maybe taillights) to flash.
Look up forscan wigwag
Any idea how to activate the wig-wags once I've made the change in forscan and grounding the one wire?
Runaway Tractor
Yes
Does anyone know if this works for the lightning? I have a 22 and would love have a seamless strobe option like this.
Yes, it will. However the bang-for-your-buck is very very low on that. Those two beacons are garbage. The replacement part for those beacons is $35, which puts it in the Walmart toy light category. SoundOff Signal makes that, and it's special product just for Ford made to be cheap garbage.
Whelen makes an F150 bracket for $325 which you can then mount any light you want on. You can put a Whelen Mini Century 16" bar on there for $328. Literally the same price and you have one of the best and brightest mini bars on the market for literally same price as that SoundOff/Ford piece of shit. If you want the actual brightest minibar, the Whelen Responder LP is a little more. Buy with the amber LEDs and clear lens. It will then also look way better and lower profile than those amber lens pieces of shit.
