Jim Lewis
San Antonio, TX
I do plan to call Ford tomorrow to find out what they mean by software repair vs. affected vehicles.
So Friday 9/20/24 I called the Ford Customer Relationship Center (CRC) as instructed on the 24B56 notice to owners if they had any questions or concerns.
For starters, the call system instructs the caller to input the CSP number on the letter to route the call. Bad start as the phone system replies, "We don't recognize that number." So, I chose the routing option that I am having trouble with the dealer.
The Ford rep who took my call was clueless on what I was calling about. He asked if he could research the matter for three to five minutes. When he got back on the line, the only advice he could offer me was to take my vehicle to the dealer. The dealer would know what to do (but I had told him my problem was I thought the dealer was misinterpreting Ford's CSP 24B56 instructions).
Then at the conclusion of our call, it seemed the Ford rep deliberately avoided hanging up on the call as a rep is supposed to do to trigger a customer satisfaction survey if the customer stays on the line... :rolleyes:
@Ford Motor Company, what's a better number than the CRC's (1-866-436-7332) to call to get knowledgeable guidance from Ford relative to a dealer who claims that only vehicles showing a front parking sensor defect, not all the vehicles in the build date range, are covered by the CSP software update policy?
Just more "Process Management" failures, I would EXPECT the call center triage system to be updated with the code and CRC specialists able to cogently answer questions about this matter, BEFORE issuing paper or app alerts.
Mike G
Mike G
N. AL, USA
Either I don't understand the issue at hand, or I'm viewing it differently.
All F-150s in that build date range are potentially affected.
So applying an available IPMA update (if there is one in your FDRS list) would fulfill that CSP and address the sensor issue as far as they are concerned. When you show up, you tell the service advisor you have an occasional front sensor warning that shows up on your IPC when you press the brake pedal coming to a stop at a stop sign with no vehicles in front of you...but that this doesn't happen all the time, just sometimes. You want this IPMA update in any case. There is no downside to getting this update applied.
You can call the Electric Vehicle Team 800-392-3673 or 866-631-3788 x79969 for any info on any topic about your Ford EV and they should be able to help.
watson123
Los Angeles
2022 Lightning Lariat ER, Antimatter Blue; Tesla Y
Attorney
I got this letter as well! Pretty cool given I'm 2nd owner.
Mike G
Mike G
N. AL, USA
May have missed it but for those that have made changes in FORSCAN to the IPMA is there anything I should do before taking it in for the update?
Nope...zero impact. Completely oblivious.
Jim Lewis
San Antonio, TX
Thanks for the advice. Before I go back to my dealer (Red McCombs Ford, in SA, TX), I will ensure the EV Service head agrees that CSP 24B56 applies to all vehicles in the build date range. And I'm also going to wait for cooler weather. I arrived at 7 AM on 9/19 for CSP 23B70 (I'd already had the software update for that checked earlier in the year). According to the CSP 23B70 tech bulletin that you posted, Mike, the BMS replacement takes 0.3 hours. I was at the dealer until 2 PM, and my vehicle was an oven when I got it back (high of 96F that day). Given the wait time for a 0.3-hour job, I expect them to have my truck sitting in a lot for a day or two for the right time to do a 2 hr 40 min IPMA update. Or, since I have a Mongoose cable and a Clore PL6100, I might give FDRS a shot. I'm such a complete newbie to FDRS that I'm not sure doing an IPMA update is the way to get rolling on that. ?
BTW, using the FordPass app, I could tell minute-by-minute where my vehicle was at the very big dealership. Most of the day, it was sitting out in the back lot.
Scorpio3d
SS/IBA car wash owner
Strange the CSP isn't showing online or in the app so far - in the past I'd get it online/in the app well before the USPS mailing - no mailing either so far.
It showed up on my FordPass app a while ago and I got a letter in the mail a few weeks later dated September 2024 as well. I had already done the IPMA update with FDRS so I called the dealer to make an appointment last week or the week before and mentioned that I needed the BMS update done while it was in the shop could not get a loaner until October 8th. Supposedly they will do all updates while it is in there, fingers crossed.??
ThunderSnoww
Kevin
Detroit, MI
2023 F-150 Lightning - Lariat ER - Antimatter Blue - BC 1.4 (on 08/15/25)
I think it killed my 12v battery too! I just had the update done on Monday and all day today, after every drive, I get the shutting off to save power message and I can’t use my FordPass app. I’ll give it a few days of driving before I bring it back to the dealer.
Same issue for me today. Posted more details in this reply to another thread.
What's your 12V status now that it's been almost a week?
MapleMan650
Santa Cruz Mountains
'22 Ford Lightning Lariat ER, 2017 Ford Mustang GT
I.T.
Still the same, all the same symptoms you listed on your thread too. I need to make an appointment to take it back to the dealer to check it out. My commute is 100+ miles round trip and that’s made no difference.
Mine is getting dropped off this afternoon for tomorrow. Completing 23B57 begun in May, 23B56, 24P24, and SSM 52574. Hopefully nothing will be left to update when done.
Mike G
Mike G
N. AL, USA
Well except the RFA and ACM that refuse to clear properly from FDRS :p
Adventureboy
Sweet. Hopefully this will just rollout OTA, it would be silly to have to make a trip to the dealer for this.
It's quite possible this module is not updatable OTA for trucks built in this date range and a physical connection is needed to update the software to "enable" future OTA updates. I don't get the error often but my dealer is pretty good so I'll take it in next week.
samskeys
Sam
Medford, MA and Parsonsfield, ME
Ford Lightning XLT 2023 SR Equipment Group 311A
I dropped mine of Sunday night for a "half day on Monday." At the end of Monday I got a call saying the update "failed twice" and they they needed it overnight to try again in the morning. Apparently its now halfway in and hopefully Ill be able to pick it up in a few hours...
Mashedtators
2023 Lariat ER
Just got back from the dealer. 2:15 total time and they did the frunk update as well.
