MapleMan650
Santa Cruz Mountains
'22 Ford Lightning Lariat ER, 2017 Ford Mustang GT
I.T.
Hey @Discount Tire how’s the stock looking for these? I just rolled over 40k on my stock tires and something tells me it’s time for a new set…
Ford F-150 Lightning Toyo Open Country A/T III EV Tires Launched: Charge Up Your Adventure IMG_5633
Pitbull2o08
Ohio
you can plug that.
MapleMan650
I.T.
you can plug that.
Yeah, that’s what the mechanic said too but with 40k on the original tires and winter coming I’d rather throw the money towards the new tires.
Good news, my local shop was able to get some of the Toyos overnight! I’ll post updates about them later.
Ford F-150 Lightning Toyo Open Country A/T III EV Tires Launched: Charge Up Your Adventure IMG_5649
Pitbull2o08
Ohio
No one has been able to order P-metric yet? I think I did see somewhere they won't be available until the end of this year though.
WoodduckMN
Andover, MN
23 Tesla Y, 22 Lightning Lariat, 21 Chevy Bolt, 13 Ford Explorer
Manager
The only place I see that I can order is Tire Rack. I call the @Discount Tire toll free number and they can’t locate the tire. They passed my information along to the local store who is going to call me back once they know more.
Update: The local store called me back, and he is a EV owner. They can special order. Toyo only made 500 sets to start with and there only around 80 left in the US today.
MapleMan650
I.T.
Damn, I was lucky! Walked into a local shop, had the tires delivered the next day before 8am.
Farmford42
WA
69 Bronco
Farmer
What’s the price these days on the Toyo s
The A/T III EV are $404 at every place I see advertise them. I still haven't bit the bullet on these yet. Seems inventory is getting low, wonder how long before they put put a second batch.
  • Wow
Reactions: N87
Magendi
Philly area
Lightning Lariat
I ended up getting the 275/55 instead of the 275/60. Saved $200 on the tires and in the stupid city garage I need to park in at work it rubbed slightly going up the ramp and the smaller tires should fix that. Basically I lost less than 1/2” in height. I did need to adjust the speedometer with FDRS which seemed to go fine. Only a couple of hundred miles and the ride is fine but efficiency seems to have taken a significant hit. I need more miles of mixed driving to confirm but it has me worried. It could be as much as 15%, which is a ton more than I expected.
I wonder if the efficiency reading is off from the different tire size? The other report on efficiency I recall said they would put it between 5-10% I think. I've also been told that A/T tires need a few 1000 miles to break them in. Perhaps the efficiency will be wonky until that point? I'm just thinking out loud as I am not super knowledgeable in this area.
Magendi
Philly area
Lightning Lariat
I hope you are right. I had them inflate to 56 lbs which I assumed would provide better efficiency (albeit a little rough of a ride). I might bump it down to 52 which was mentioned in the thread as potentially optimal to see what that does to ride quality and efficiency. I wouldn't think that a 1" change in diameter would cause a massive change in efficiency but maybe I am wrong in assuming that. Time will tell.
Chriseberle
F150 Lightning SR Tesla Model X
Have the same tires and run them at 45PSI but I have 275/60, they will ride a lot better.
Well, I finally decided to take the plunge and splurge. Called my local Discount and they sourced a set that should be in around Oct 18th. Tires, tax, and Discount certificates has me out the door around $1800. A bit more than I anticipated for tires but I'm looking forward to checking them out. Hopefully they last longer than the stock Grabbers. I don't mind paying the premium for good tires if they deliver.
JPro
Vancouver, WA
22 F150 Lightning Lariat SR
Rebar Detailer/Estimator
Is the different size you bought still the AT3 EV version or the standard AT3? I wasn't aware they made other sizes in the EV version yet?
Magendi
Philly area
Lightning Lariat
Yes, they are EV. Toyo now list three sizes as currently in production but these I could find only at simpletire.com
