Erratic charging from 85% - 90%
Adventureboy
What was the SOC when you picked it up at the dealer? How many KMs on the truck? It can be the battery pack may be a bit out of sync from sitting and inconsistent charging, or from a number of things already mentioned.
If the pack is a bit out of sync from sitting or just because it is new, it should settle under normal, regular use.
user-name-required
user-name-required
T
BC
2024 F150 Lightning Flash, 2023 ID4 pro S
They charged it to near full for me, I think it was at 99% when i got it.
Glad to hear posting this that no one else had seen it before. These EV forums are pretty handy sometimes when dealers don't have answers
sd25
NJ
2022 F-150 Lightning Lariat ER, Rivian R1T
Ok, is no one asking about this little item? Which update added this? Have a 2022 and have been missing having this useful piece of info when charging.
Ford F-150 Lightning Erratic charging from 85% - 90% Untitled
Comes with all 2024 Lightnings, when we will see it as an OTA, no one knows......
Ishkatan
Adam
Monrovia, Md
2023 F150 Lightning Lariat ER =RAe (Range Anxiety)
Old
I saw my 2023 Lariat ER do something like this, though not as extreme when on a 7kW charger, one time. I usually don't bother watching it. The Ford app shows a steady number that decreases as the charge state goes up.
I recently was charging at an EVgo and it went quite fast but while I had it set to 100% the charge stopped at 97%. I suspect the truck said "enough for now" and the charger shut off before the truck said "i'm ready for more". When charging I hear fans going to cool the battery.
invertedspear
AZ, USA
lightningcalcs.pages.dev
Very, very seldom would we need to DCFC to 90 or 95, but I still wanted to see what it looked like as there's still some stretches here where I live in BC (entire province is mountainous) where you're ~250 kms between chargers that can do over 50kw....so for when we are towing, it becomes more of an issue.
I know I'm kind of late to this conversation. And I 100% love driving my lightning, and highly recommend it as a city truck. But if this is a worry I don't think the lightning is the truck for you. Consider a powerboost instead. Or wait for the powerboost to be a PHEV, or look into the Ram Charger in the next couple years when it launches. Especially when it gets cold in BC, even with the heat pump on the 24, you're going to suffer a range hit on the temperatures. It's not a safe bet that the F150L is going to get you through when towing.
potato
BC, Canada
2023 F150 Lightning XLT ER
They did say they were already towing with their other EV, so I think they know what to watch out for. I agree if towing long distances is the *primary* use case then maybe the Lightning isn't the best choice, but if it's occasional, and mostly in good weather like typical camping uses, it'd be OK.
As for the original question. I have not seen charging rates jump around like that. My 23 XLT ER drops suddenly to 55 kW or so at 80%, then flat up to 89% or so, then tapers off again after that. I'd be interested to see what the truck and charger are telling each other while it's behaving erratically. Car Scanner might offer some insight. Maybe some strange interaction with that particular charger.
user-name-required
user-name-required
T
BC
As noted, yes we tow already with our ID4. Our trailer is a tent trailer and with the ID4, it has a vertical bike rack off the back of it....aka a giant air brake. We can get about 180-200kms between chargers with that thing, while "clean" on the highway on a trip like this, we could get about 350 if we really pushed it. 250 if we had the vertical rack on the car instead.....crazy how much aerodynamics impacts efficiency!!
Yes the extra size of the battery on the lightning, combined with the reduced impact to it from towing (relative to the ID4), I think it will do just fine, and enable us to get 250 kms comfortably. From my testing at hwy speeds with it, I got about 40kw/100kms towing the tent trailer, and about 35-36kw/100 km on the highway without it.
With a 131 kw capacity, i should be able to get 300kms using 120kw of juice on one leg, charge back up to 85% (111kwh), and then drive it back down to 10-15% and use 90-100kwh of power and get another 200-250kms. There really aren't any legs of our trips where we would be doing more than 500kms driving in a single day. So, with the lightning, it could become a single stop day instead of a two stop day, which would be great.
