Both Front USB Ports Will Not Charge
strmwzrd
Nebo, NC
F-150 Lightning Lariat
The charge pad works though. The same two cables work on the ports at the back of the center console too. Anyone ideas?
Ford Motor Company
Official Ford Account
F-150 Lightning
Hi there! Would you send us a private message with your VIN and dealership name and location? I’d like to look into this concern on my end.  
Could be loose connector under the console
Maybe check for a blown fuse?
The frunk fuse block there is fuse 125 which powers both USB1 & USB2, and fuse 139 powers USB3,
Ford F-150 Lightning Both Front USB Ports Will Not Charge 1728966360729-uv
Ford F-150 Lightning Both Front USB Ports Will Not Charge 1728966516243-8a
Ford F-150 Lightning Both Front USB Ports Will Not Charge 1728966399142-l
Adventureboy
Start by restarting the Sync system. Press and hold the volume down button and the skip right button on the steering wheel for 10 seconds or so and it will restart. Check again. I had this happen a couple of times on mine and the restart clears it.
strmwzrd
strmwzrd
Nebo, NC
Thanks. I'll gave it a try--no go. While at my sensor-software recall my dealership ordered me a new module, more to follow...
MTBAZ
Dan
AZ
22 Lightning Lariat
Not that I know what to do next, but do the USB ports in the center glove box work?
