Mildew/Musty/Moisture Smell Upon Fan/AC turning On
queuewho
Western PA
22 F150 Lightning Lariat SR
Model 3's have this issue as well but it was much worse. I used kool-it to clean its insides. With my truck, I always turn off the AC a couple minutes from home, or I let it run in my garage while unloading, with the AC button toggled off.
scruvs
I've been a Ford owner for eons, the problem developed on all my former trucks....
Tips from my favorite PowerStroke technician!!
I was scared to drill the hole through the plastic like that Powerstroke tech.
So, I ordered this less-expensive product from Amazon:
Kool-It
It has a hose that inserts up through the A/C drain opening underneath the truck. The entire contents of the can are dispensed as a foam through the A/C drain. Wait 15 minutes, then turn the A/C on low for five minutes.
My thoughts and things I learned:
This Kool-It product smells like spearmint gum. It definitely fills the entire A/C system with foam. After five minutes, I turned my A/C on high and foam was blowing through the vents in my face. So, I switched it to low for another 10-15 minutes. It's hard to tell how much gunk is removed from the evaporator because the discharged foam drips all over the frame of the truck before landing in the catch pan, or more often, on the tarp next to the catch pan. Inserting the product through the drain did not require the cabin air filter to be removed. I checked the cabin air filter afterwards, and it was not wet.
Below are images of the A/C drain. The drain is located behind the front, passenger wheel well liner. If you lie down behind the front, passenger tire and pull the wheel well liner toward the outside of the vehicle, you'll see the drain. See images below.
Definitely place a tarp under your catch pan. This stuff drips everywhere. Next time, I'll wear safety glasses. A lot of debris falls from the wheel well liner. I'll wear latex gloves next time because the spray top doesn't attach all that well to the canister for the product, so some leaks onto hands.
I'm hoping to get a couple months of good smelling air out of it, but I'm going to order another one or two cans to have on deck when it's time.
Edit: When I reordered, I decided to try this Kool-It product below because it describes the scent as "Fresh" instead of "Mild Spearmint," and I'm curious if it's a different fragrance.
Kool-It Fresh 2-pack
Ford F-150 Lightning Mildew/Musty/Moisture Smell Upon Fan/AC turning On IMG_1817
Ford F-150 Lightning Mildew/Musty/Moisture Smell Upon Fan/AC turning On IMG_1815
zinkscott
Christian
2023 F-150 Lightning Platinum
Cloud Engineer
I just started experiencing this.
62F1004x4
Norman, OK
1962 F100 2023 F150 Lightning SR
Maintenance
Same here, maybe the time of year when AC is not used as much? Not enjoying the musty smells.
zinkscott
Christian
Cloud Engineer
I didn’t have this problem, been using AC all summer. Dropped it off for CSP and it’s been about a month since I’ve used AC and it started happening. Gonna try the Kool-it kit.
Ford Motor Company
Official Ford Account
F-150 Lightning
Hi David! I can look into your Lightning's concern on my end. To get started, could you please send a private message over with the name/location of your local Ford dealer and your Lightning's VIN?
62F1004x4
Norman, OK
Maintenance
Thanks for the quick response Ford Motors! I sent a PM.
zinkscott
Christian
Cloud Engineer
scruvs
One of us got a reply ?
I’ll be curious what your dealership says. My dealership says it’s not covered by warranty because it’s caused by the outside environment. They quoted me $200 to treat the A/C. We went back and forth for a couple of minutes and the dealership generously comped the treatment service. The A/C smelled good for a week, but didn’t fix the problem.
Hceren
Heath
Houston, TX
2023 F150 Lightning
Data Architect
I recently traded in my 2023 Lightning Lariat for the 2024 version (better monthly payment; better warranty).
I experienced the smell issue with my 2023 but haven't had any issues with the new truck just yet. I would even have the smell sometimes before turning on the air. I fully believe there was an issue with a seal somewhere in the car as well as water getting trapped somewhere in the cooling system.
Will be interested to see how this is resolved.
RocketGhost
Spencer
Memphis TN
2022 Lariat ER
The fabric mesh windscreen of the sunroof will mildew. I have the smell too, not sure if that's the culprit, but when I put my nose up to it I definitely smell the funk. I have to think that most of the smell is coming from somewhere else. Fortunately I have a garage so when it gets stinky I park it with the windows down and sunroof open.
scruvs
I liked this “Fresh” scent better than the “Mild Spearmint.” And I feel like the fresh scent lasted longer than the spearmint.
I left the juice in longer than the recommended 15 mins. I left it in 30 mins or so to allow most of the foam bubbles to dissolve and a lot to drain out before turning the AC on low to flush it out.
bigE
Eric
F150 Lightning (EV)
I just wanted to thank y'all for this great thread! I've been happily driving my truck for a year and a half before this problem popped up. It was a relatively easy fix. Thanks!
scruvs
I just re-applied. I probably started noticing the smell a month ago. So, looks like I got from Jan - May in central Florida. But, I think every two months is typical for me. But, that’s ok because it’s cheap and easy…even if it only masks the issue.
EMdoc12
TN
Tesla Model X, Land Rover Discovery
Physician
I've never had this problem on any of our 5 previous Tesla's. Never happened on our expedition either. My lightning Platinum is 6 months old and doing it now.
Definitely glad it's a lease as I won't be going through all this shit all the time. I shouldn't have to turn off the AC either. The truck should be smart enough to keep the fans going after it's shut off to prevent this from happening in the first place.
