Overheated bed camera
Stevie Wonder
Steve
North GA
2023 F-150 Lightning XLT, 2018 F-150 Lariat
9/13/2024 Update: Connected the scan tool to the truck today to confirm no more DTC's after Tuesday's service. Found 2 codes being reported:
- PSCM U023A:00-28 Power Steering Control Module / Lost Communication with Image Processing Module A
- IPM-A B152E:55-2F Image Processing Module A / Rear Camera 2
I successfully erased the PSCM error, but the IPM-A error appears to be a "hard failure" as I cannot clear it.
Took it for a short test ride; no warnings in the instrument cluster and all cameras appear to be working, including the bed camera which was replaced this week.
Will check back with the dealership next week to see if this a non-issue that will go away on its own since there are no warning indicators in the instrument cluster, or if it needs another service visit.
Tune in again next week, same bat-time, same bat-channel ;)
Stevie Wonder
Steve
North GA
11/6/2024 Update: Took the truck to the dealership last week for a Battery Energy Control Module issue (Service Vehicle Soon / Wrench icon lit), so I asked them to check on the IPM-A/Rear Camera 2 error too.
From the Repair Order: "Ran the IMPA module PMI, Ran the LIN module initialization, Ran camera calibration road test."
I have scanned for DTC's a couple of times since the repair, and the IPM-A code has (so far) not come back.
As for the Power Steering Module "Lost communication" error (see 9/13 post), the Service Advisor said that in his experience, the F-150 Lightnings tend to have various random "Lost Comm" errors between different modules, due to the 40 to 50 modules all constantly trying to keep track of one another.
MichaelCA
MichaelCA
'22 Lighting ER, '22 Tesla Model 3, '16 Mustang GT
I do recall seeing a ton of errors from forscan but no lights on my dash.
Joneii
Central PA
F-150 Lightning, Tesla MY
Does anyone know if the replacement camera is actually different? Was there a bad lot of cameras or are all of our cameras subject to heat exhaustion? I park under cover in PA, so have not experienced this issue. I’m also well out of the factory warranty, so is my camera going to fail during a summer trip to New Mexico? This seems like it should be a CSP if it effects all of the cameras.
Hard to say how fast mine died. I hadn't actually used that camera until I saw this thread. So 2nd summer in full Sun at minimum. I checked it a week or two ago and it was still good. Will be interesting to see if makes it through next summer. Glad I picked up the extended warranty if it doesn't.
boggle
CT
MY23 PRO
Any updates on you guys that got these cameras replaced, how have they held up? Mine has started doing it consistently when hot, wanted to make sure that the replacement does actually fix it.
Ford F-150 Lightning Overheated bed camera 1752495546040-kg
DoyouLightning
BK
Charlotte NC
23' lariat ER
I had mine replaced by the dealer about 6 weeks ago and it has been flawless since. On top of that we have had 90 plus degree days straight in the the south east. I was told my wife harness has melted in the heat prior and that was the reason mine failed. But I still park it outside in the sun. Seems to me Ford should have designed the roof compartment with some heat sheilding or some better connector to prevent this.
But if your under warranty they will fix it just depends on how long it takes them to get the part.
MichaelCA
MichaelCA
Mines been good so far. It gets hot here so my camera gets the heat cycles and it’s still working.
Stevie Wonder
Steve
North GA
September will be a year since camera replacement. Parked ours in the sun for several hours today. Camera temperature 133 degrees, roof sheet metal 177 degrees, and the bed camera is working fine.
DCAZEV
Phoenix, AZ
2023 F-150 Lightning Lariat ER / Avalanche / Max Tow /
Self Employed
Same Issue here. The hot weather here in AZ causes these cameras to go out. I called the dealer today and they want me to drop off the truck and leave it.
duncanmclain
Duncan
St. Louis, MO
F150 Lariat ER
Supreme Galactic Commander
Dropped mine off at the dealer this morning. Ironically now that the temperature dropped it started working but I submitted photos of it not work just last week.
boggle
CT
MY23 PRO
Finally had a chance to try to get his resolved. Dealer refused mobile service as they weren't sure they could perform the repair in the field. They picked up my truck this morning and of course can't replicate now that the weather has cooled down. The numerous videos and pictures I have apparently aren't satisfactory and they now want to hold it until the weather is hot enough to replicate themselves. Why is this such a difficult process @Ford Motor Company?
UPDATE: Service advisor called and now will be ordering a camera for install tomorrow. Why it wasn't just ordered when the service was scheduled...
scruvs
if you get it back unfixed, I wonder if you can simulate hot weather with a heat gun — one block from the dealership.
I also wonder how much this part costs. It’s the same part as the ICE trucks right? Is it plug and play behind the brake light?
I’ll see if I can find any videos on replacing this. If the part is cheap enough, sometimes the warranty repair is outweighed by not having the truck.
boggle
CT
MY23 PRO
Should be plug and play. Believe it's the NL3Z-13A613-A which is going for over $500 on ebay. The more I look at the price of these parts the more interested I become in the extended warranty, would suck to lose the trailer assist because these keep dying.
