potato
- First Name
- John
- Feb 1, 2024
- BC, Canada
- 2023 F150 Lightning XLT ER
I mean, they only said that they did it and it worked. That cannot be wrong if it worked.Post 36 is wrong. Post 24 explains why. If you modify the plug, or an adapter, to make it physically connect to your other EV, it may work or it may not, depending whether the vehicle you're trying to charge implements the required signaling - which is not needed in cars that have only Level 2 charging support, not CCS DC.
With full EVs, excepting early Teslas that had no CCS support, it will likely work. With PHEVs, it may not.
Inferring that it would therefore work for all PHEVs might be wrong. But the post didn't say that.
