F150 Lightning FORscan thread
mattymcnuggets
Matt
2023 Lightning Pro
Did you save the a/b data before you started making any changes?
Edit: Oh wait....this requires actual programming.....it isn't just config. I assume you don't have FDRS?
I do not
Honito
Jon
2024 Ford F150 Lightning Flash ER
Successfully did anti-glare on 2024 Flash last night. Confirmed the bending light still works too. Awesome feature, thanks for the info!
Athrun88
Toronto, Ontario, Canada
Want to thank all those to walked the path before me. Just did anti-glare and disable startup boot animation on the 15" screen. Swivel still works great as well.
Wsl346
Austin, Texas
Is there any benefit to disabling the startup animation? Could you link me to the location in this thread where the config is located?
Athrun88
Wsl346
Austin, Texas
3rdgenfan
Geoff
Delaware
Cybersecurity
https://www.f150lightningforum.com/...ngs-chimes-honks-bings-bongs-and-dongs.18175/
It boots into the main UI (AA in my case) faster and don't need to be hit with the long animation. Also tried to disable the triple chime on start up but the change didn't take, may need to try it again later.
Getting rid of the chimes has been a wonderful change. Between the normal chimes and some errors during my comma 3x boot up it was a 30 second artillery strike of bings bongs and beeps.
Athrun88
Is the module in the linked thread the correct one? I have a '24 Lariat so I'm not sure if something changed for the 2024s. I did pull the module last night and the change was written. I'll have to check again during my lunch break because those dings at the beginning are really annoying.
EDIT: Seems that I may have just needed to reboot the truck. Tried driving it now and no triple ding on startup! Nice to have less noise in an EV!
Fxnitro
PA
F-150-Lightning XLT ER 2023
Help!! almost done installing Adaptive cruise control on my 2024 XLT, but i keep getting a DTC related to IPMA configuration being incompatible.... i cant seem to figure out what values i need for:
706-02-01 *xxx-xxxx-xxxx ( factory numbers in those blacks are ) 2B67-FFCC-016E
And
706-16-01 xxx*-xxxx-xxxx ( factory numbers ) 024C-0000-0073
I looked up in the library but doesn’t seem to include the values I need for my truck
PJnc284
Garner, NC
Above my paygrade but mine for a 2023 Lariat are as below. Since yours is a 2024, it may require different values.
706-02-01 7373-FFCC-8142
706-16-01 124B-0000-0081
marc088
Marc-André
2024 XLT
And
Hi! Where did you found informations regarding adding this to your XLT 2024. I found detailed stuff regarding pro 2022 models adding ACC+ Lane centering. Ours 2024 XLTs already have lane centering.
Could you please what parts you had to buy and at what price? Thanks!!
Fxnitro
PA
I just did it for my 2024 XLT, it’s about 500 for all parts and a few hours of your time. Find the thread called diy adaptive cruise control install by brotato and Hhunterfamily on this forums all instructions and all problems you will encounter will be there.
CRAIGC540
Craig
Moreno valley
Technician
I wonder if this is why my glare-free headlights are working so awkwardly? I'm going to try this tonight. Thanks for sharing!
When you say "working so awkwardly". How so?
