astrand1
Alex
Studio truck driver
lightning-spark
Vancouver, Canada
2023 F150 Lightning Lariat ER
Thanks for the camera one. I'll check it out. The spreadsheet you embedded looks like Livinup's. I posted a link to it in post 1. I always vet each mod against that spreadsheet. Many of the parameter bytes can control 4 functions (e.g. "F" = binary "1111") so you can't willy-nilly change to one specific value. I take that into account and where applicable give instruction on what the value should be based on the current value so you don't inadvertently lose functionality.
I have the black box removed on the reverse camera and it works just fine. I edited my post to remove the spreadsheet. Cheers.
moodinsk
Tyler
2024 F150 Lightning Flash
Enable B&O Beosonic Equalizer (B&O Sound systems only)
APIM 7D0-01-01 xxx* xxxx xx-- Add 8 to * (mine was "1" so made a "9")
DSP 783-01-01 xx*x xx-- Add 1 to * (mine was "0" so made a "1")
Hey all,
Looking for any insight on these settings. I have brand new 2024 Flash with the B&O sound - should be the same as the Lariat.
I made these adjustments via forscan. I get the menu options "Equalizer" and "Beosonic" under Tone Settings, but I am unable to actually tap on either of them. They do nothing at all. I originally made the changes last night. I tried the module reset in forscan, left the door open with the truck off for 10 mins, and finally let it sit overnight... still nothing.
This morning I reverted the changes and was able to get the default Treb,Mid,Bass sliders back and they worked fine.
Just tried applying the edits again and I get the same thing. Menu buttons are there, but nothing when I tap them.
Anyone else with a 24 Flash able to get this working?
ps. I was able to get the glare free matrix headlights functioning, tested them last night! very cool
jlcreasy
2023 Lightning Lariat
Help, I made the changes for the glare free headlights but when I go to the vehicle setting page for lights, I see the road driving side is set to left. I cannot change the driving side from left to right? I hit Right and it resets 5 seconds later to left. Any ideas?
I'm not sure what you're seeing re road driving side. Here is my Lights section
Ford F-150 Lightning F150 Lightning FORScan thread - Version 2 1735920068814-ev
Did you change 7D0-02-01 by mistake? It has a setting for Vehicle Driver location. I suggest revert your APIM settings to the backup you made and try again.
I'll do the reset and see what happens....
There are a couple of APIM changes that might turn that sub-menu on
7D0-09-01 *xxx xxxx xx-- AEIS Without Override (AEISWO) • AEIS with Override (AEISO) • ACC Menu (ACCM) • Adaptive Head Lamps Control Function (AHLCF)
7D0-09-01 xx*x xxxx xx-- Autolock Control Function (ACF) • Adaptive Head Lamps Traffic (AHLT) • Auto Relock (AR) • Autounlock Control Function (ACF)
I'm guessing you may have fat-fingered one of these by mistake.
I added to main thread. Thanks again!
moodinsk
Tyler
Hey all,
Here's a screenshot of the menu that I am seeing with the below settings:
APIM 7D0-01-01 xxx9 xxxx xx--
DSP 783-01-01 xx1x xx--
Tapping either of them does nothing at all. No beeps or button interactions.
Any thoughts?
Ford F-150 Lightning F150 Lightning FORScan thread - Version 2 IMG_1904
Any thoughts?
Here is what I see. I am able to switch back and forth between Equalizer and Beosonic with controls for each. Have you tried resetting Sync?
Ford F-150 Lightning F150 Lightning FORScan thread - Version 2 1735931498506-q
Ford F-150 Lightning F150 Lightning FORScan thread - Version 2 1735931526249-dn
Scorpio3d
SS/IBA car wash owner
I really don’t understand why Ford includes all these cool little things in the software, but does not make them active???
Any thoughts?
moodinsk
Tyler
Thanks for the suggestion.
I originally tried resetting APIM via forscan with no success. I just tried resetting sync by holding vol- and skip.. same thing.
I will try pulling the battery neg for a bit tomorrow and see if that makes any difference.
I wonder if there is some change on a new 2024 flash that stops this from activating properly? Would love to have another 24 Flash owner confirm if this works for them.
JPro
Vancouver, WA
22 F150 Lightning Lariat SR
Rebar Detailer/Estimator
I can see my glare free matrix headlights working to block around oncoming traffic but they don’t seem like brights in the Green “A” auto lamps setting, do I need to pull the stalk until the blue brights indicator is on? Alternatively is the matrix feature fairly lackluster? I’m just not sure if it’s working as intended, I think I liked the original auto high beam better.
I checked the spreadsheets. For some modules the 2024's have a different version. But for the listed parameters they stayed the same from 22 to 24. Maybe the DSP is newer though. My DSP module Strategy Code is ML8T-14C589-AD according to FORScan.
21st Century Truck
Martin
Any thoughts?
To differentiate trim levels across the entire customer fleet.
