Home Assistant - Ford F150 Lightning Dashboard.
zinkscott
Christian
2023 F-150 Lightning Platinum
Cloud Engineer
This one is nice as well. Mind sharing? Or was this one already posted earlier?
I've taken parts from quite a few - one originally posted here I believe. I don't mind sharing. I also have some templates made, included in the GIST.
EDIT: Make sure to change your device ID in the `navigation_path` lines if you copy these.
linuxgangster
shane
2023 F150 Lightning xlt
Where is the navigation bits coming from?
queuewho
Western PA
22 F150 Lightning Lariat SR
I set mine up about 2 months ago and it’s been working fine.
You must clear out any downloaded version via HACS and then manually install 1.70 per repo instructions.
EDIT: image
Did you just scp into your backend files and copy 1.70 into some specific folders? Didn't see specific instructions on the manual install.
IIRC I just downloaded the files from the GitHub site and then overwrote the same files on my HA box but keeping my existing token file there.
\config\custom_components\fordpass
queuewho
Western PA
Thanks I'll try poking around in the container later.
Aminorjourney
Aminorjourney
Nikki
Internet
www.transportevolved.com
2023 F150 Lightning Lariat, 2017 Chevrolet Bolt EV, 2006 Vectrix VX-1
To add my voice back into this - sorry -I've been avoiding social media and forums of late because... *things* - I'd note that this integration does now require you to do a little leg work to keep it working.
The GitHub is pretty clear now - https://github.com/itchannel/fordpass-ha - but I would advise if you're anything like me to read it a few times before you try anything, otherwise you will end up scraping your head and screaming.
My system has been working with V 1.70 for literally months now and it's great. I don't have a very frequent refresh interval on purpose, because really what I use this for is remote starting of our Truck on a cold morning or hot afternoon.
We also use it to pipe info to our smart display switches so we can see at a glance how much range each of our EVs have (my bike hasn't got telematics... sad face)
Ford F-150 Lightning Home Assistant - Ford F150 Lightning Dashboard. IMG_7112
Ford F-150 Lightning Home Assistant - Ford F150 Lightning Dashboard. IMG_7110
Ford F-150 Lightning Home Assistant - Ford F150 Lightning Dashboard. IMG_7111
linuxgangster
shane
Same with me. I just got my truck and this integration going. I pay more attention to the automation I have built with the Emporia Vue and EVSE along with Solar Assistant. Right now I am refining how I am automating the EVSE to charge my truck based off of my House battey SOC and calculating the excess solar. I wish the Emporia Vue could do what I want but this gives me an excuse to code something. Right now its pretty close to how I want it, I just need to weigh rather or not its worth my time to do it in a more geeky elegant way.
Well based on my file dates, I'm running 1.68 using a token file. It has been working since May 10. But yeah, you should probably use the 1.70 instructions.
zinkscott
Christian
Cloud Engineer
Fistandantilus
Germany
2023 F150 Lightning Platinum
Got my integration working today as well. Thx for the valuable input from here. Used the repository marq24/ha-fordpass to install the branch via HACS (does not require copying files).
My Dashboard right now looks look that way:
Ford F-150 Lightning Home Assistant - Ford F150 Lightning Dashboard. IMG_0441
queuewho
Western PA
I managed to get the 1.70 files copied to my container, working fine again. It's good to know there's once again an active fork for the future though.
Now that I am set back up...I'm trying to come up with a set of refresh automations that increase the frequency of refreshes when plugged in, and even more frequent while charging. Would be nice to see the charge curve in HASS on a graph.
Fistandantilus
Germany
I think you just need to see how frequent you can refresh the data before the account gets blocked. Have the same issue with our second car (Audi Q4). I have set both to 15min just to be on the safe side. Hopefully the vendors do at some point in time not check for patterns. Don‘t know why they are the strict whit accessing the data?
Aminorjourney
Aminorjourney
Nikki
Internet
Looks great! I also think Marq24 is in Germany, so you may benefit from regional fixes as they are required! ;)
Because I was bored, I switched over to the marq24/ha-fordpass repository. It inserts the vin into every sensor entity and moved a few things around. I got most of my dashboard working but I am unable to display individual tire pressures anymore. I see you have them.
The individual tires are attributes of tirepressue and in the past I used a template variable to read the tirepressure attributes. So I modified my templates to use the new sensor and attribute names like this (but it does not work). I get null.
{{ state_attr('sensor.fordpass_1ft6w1ev5xxxxx547_tirepressure', 'FrontRight') }}
I was able to get the 12V battery voltage attribute (not SOC) to work though:
{{ state_attr('sensor.fordpass_1ft6w1ev5xxxxx547_battery', 'BatteryVoltage') }}
Can you share your code for tire pressures?
Fistandantilus
Germany
Because I was bored, I switched over to the marq24/ha-fordpass repository. It inserts the vin into every sensor entity and moved a few things around. I got most of my dashboard working but I am unable to display individual tire pressures anymore. I see you have them. The individual tires are attributes of tirepressue and in the past I used a template variable to read the tirepressure attributes. So I modified my templates to use the new sensor and attribute names like this (but it does not work). I get null. {{ state_attr('sensor.fordpass_1ft6w1ev5xxxxx547_tirepressure', 'FrontRight') }} I was able to get the 12V battery voltage attribute (not SOC) to work though: {{ state_attr('sensor.fordpass_1ft6w1ev5xxxxx547_battery', 'BatteryVoltage') }} Can you share your code for tire pressures?
