Issue programming a new key
Mach Turtle
Central California
2021 Mach E, 2024 XLT
Bum
Agree with the principle that following what other users have done is generally better than following the manual. I followed the manual very carefully (timing, key placement, etc.) about 10 times to program the third fob for our Mach-E and it didn't work. Then watched a 'Tube video where someone programmed a third fob in an Explorer. The video showed the fob being placed in its holder backwards from what the Mach-E manual clearly stated. Worked on the first try when I placed the fob "wrong."
The manuals are written by humans, but a little more care wouldn't cost that much and would make customers a lot happier.
CptnWookenstein
Western North Carolina
Lightning Flash 24 - #TeamAvalanche
So I got the AliExpress key, did all the steps… twice now I’ve gotten the key programming successful prompt. But immediately after it doesn’t work, I’m not sure what’s happening since I did get it “successful”.
Any ideas?
TechnoSwiss
2024 Ford F-150 Lightning Lariat Carbonized Gray Metalic
Electrical Engineer
Any ideas?
Just ran into this issue myself, Ford changed the frequency for the TMPS sensors, and the Fobs from 314MHz to 433MHz, so if you picked up a Fob that was designed for a 2023 or older Lightning, it's on the wrong frequency. You can still program it, and it will still work in the backup slot, but nothing that requires RF will work,
CptnWookenstein
ahhhh interesting. Mines a 2024 flash. So you’re saying if I found one at 433MHz it would work?
TechnoSwiss
Electrical Engineer
That would be my guess, it's possible not all 2024 got the change, might depend on trim level and build date. I just used a Flipper Zero to confirm what the original was operating at 433MHz, and then checked the new one and realized it was at 315MHz. I'm not having any luck yet finding one that's 433MHz with both a Frunk and Tailgate button on it, short or buying it from the dealership, but don't want to pay that much for one.
CptnWookenstein
That’s interesting. So this was purchased based off a link from another thread on how to 3d print a case to make a diy PaaK of sorts. I got the 315mhz and yeah it basically is a dud seems like, but this could explain it.
Pretty good reason to get a flipper zero as well tbh haha
PJnc284
Garner, NC
Ordered one from amazon for giggles since I figured returning it would be easier than aliexpress. No dice on a 2023. It seems to enter programming mode since it shows the factory door code after the second fob, but pushing the start button the last time does nothing and then gives a "Key Program Failure" message if pushed again. oh well.
I just finished programming a spare I got off AliExpress for $31 shipped. It took me 4 or 5 attempts before it was successfully programmed. This fob has a remote start instead of the frunk and the remote start actually works. It also has a tailgate button which works. The downside is no frunk, but I only got it as a spare in case I lose an original one.
Another member mentioned this one in another thread, which is why I picked it. Took 8 calendar days to reach me, so fairly quick. It is #4 (315MHz) https://www.aliexpress.us/item/3256806449670553.html
#4 looks like it has a trunk button in the picture? That the one you received?
sstevetx
Steve
Yes, it opens the tailgate.
Thanks Steve. I bought this exact remote - took about 9 days to arrive. Like you, it took a few attempts to program. I have Easy Entry/Exit turned on and that got annoying with the seat moving back and forth so I turned it off in Sync settings. It programmed next attempt - probably coincidence.
FYI, if anyone wants to verify the frequency of your original remote (315 or 433), look up the FCC ID. You can find it in tiny print if you remove the physical key and look inside the exposed slot. The FCC ID of my fob was M3N-A3C054338. From the FCC website, this is 314.95 MHz.
Ford F-150 Lightning Issue programming a new key 1738190470186-as
PJnc284
Garner, NC
Finally got mine. Took about 2 weeks. First attempt failed but took off the cover and the battery wasn't seated. Programmed successfully the next try. Lock, unlock and the tailgate works fine but remote start doesn't do anything. Wonder if something is different with the 23's.
TechnoSwiss
Electrical Engineer
Is remote start supposed to work on the Lighting? I thought all the factory fobs had the Frunk button there and the remote start (aka climate mode) only worked from FordPass app? I picked up a remote with the remote start instead of the frunk button because it was the only one I could find in the 434MHz range that my 24 Lariat is using, figured I could live without the frunk on my spare key.
Kansan
Wayne
2024 Flash
Civil Engineer
This is very interesting. I think you're saying that the remote start button works to start your truck - is that what you meant? If so, when you remote start are the climate settings where you left them when you shut down?
I have line of sight to my truck while at work, and my remote can lock and unlock the doors from my office chair. When outdoor air temp was -5F the truck went into deep sleep mode (locking out Ford Pass) and I was wishing for a remote start from my key fob.
PJnc284
Garner, NC
Well guess the trick is to hit the lock button followed by the remote start button twice. After starting, this is what I see in the app so it seems to take whatever settings you have set in the app. Repeating the process while running is supposed to extend the time but didn't see the ford pass app update. Pressing the remote start button once turns the truck off.
Ford F-150 Lightning Issue programming a new key 1000008615
Yes, since we don’t have that feature out of the box, it’s not in the instruction manual (I don’t think). But on other Fords we have had, that was the process. Here’s the entire instruction note:
https://www.ford.com/support/how-tos/keys-and-locks/key-fob-and-remote-start/remote-start-system/
Describes extending time, memory seats, etc. Says it even turns off radio. As they say, YMMV.
TechnoSwiss
Electrical Engineer
Ah, well that explains why it wasn't working for me. Thanks for the clarification and information, now I just have to wait till after work to try it out, since that fob is sitting at the house. :ROFLMAO:
