Andrewbens
Modesto
Lightning
Mechanic
Just mounted the Open Country AT III EV, 275/65/R20, in 116H (not the E rated tire).
Running them at the factory PSI of 36, per Toyo's input.
Have to say, 50 miles or so in, and they are super quiet with no noticeable difference in handling or ride comfort. And they look great. So far so good.
Will see what the range impact winds up being, 800 mile road trip next month.
Post some pics!
Mcfly
Billy
Socal
23 Pro SR
Realtor
Couple quick ones from the tire shop parking lot. I’ll snap a couple more when I get home and put in my thread.
Looks great! Just to confirm your tires are 275/65/R20? I'm about to buy this size as well, they are around 1 inch taller in diameter vs the stock 275/60/R20. Are you running a lift in the front or stock? Any rubbing?
deltalightning
Andy
NE Louisiana
2024 Lightning
correct on tire size yes. And yes i have the 2” front puck lift from rough country. Zero rub.
Mcfly
Billy
Socal
23 Pro SR
Realtor
Thanks! I have the same pucks ready to be installed. Does your truck still have some rake? I'm thinking mine will sit a little over an inch higher in the rear after installing the pucks.
deltalightning
Andy
NE Louisiana
2024 Lightning
Yes, still has rake, which is a good thing. Very happy with how it looks and drives after the pucks and tires.
Mike G
N. AL, USA
That's the same ones I got. Ford had a deal on them a few months ago when they first came out. Here's what they sell for today (in my area). 12 on hand in the local warehouse.
You don't have to buy them from Tire Rack..your Ford dealer sells them...
Ford F-150 Lightning Installed Toyo Open Country AT3 EV 116 T XL All-Terrain Tires TOYO_AT_III_EV
Ford F-150 Lightning Installed Toyo Open Country AT3 EV 116 T XL All-Terrain Tires TOYO_Tires
Nikola 369
Pella, IA
2022 F150 lightning Lariat SR & 2024 Kia EV6 Wind w/ tech package
Sales Engineer
42 psi?! Why is everything I see say 35psi? My OEM hancook tires wore horribly on the outside edges of the tread... maybe being underinflated didn't help?
Best to look at drivers door pillar sticker. 22’s & 23’s came with two tire brands. This led to a TSB from Ford when they discovered many trucks with 116T tire ratings and 42PSI marked on pillar, had the TPMS set to 36PSI. The 36PSI tire pressure is correct for 115T rated tires, but an issue for 116T rated tires. Due to the higher load rating on 116T tires, I think this yields a better result than 115T at 36PSI. You will have less rolling resistanc, but if you switch from what your truck is marked, I suggest having local dealership set TPMS to the corrected value and updating door pillar for the next possible owner.
JHC283
Josh
2024 F150 Lightning Flash
Farmer
Interested in these. The price is borderline nauseating. The Toyo’s look neat, but the Rivian spec Goodyear Wrangler Territory AT is $573 less per set. Maybe I need to search marketplace for some Rivian take offs.
Kniaz
Ivan
CA
F-150 lightning lariat ER CarboneGray
Toooooo mach price!!!
https://www.walmart.com/ip/Sailun-T...ain-275-60R20-115T-Light-Truck-Tire/865102918
$169.10
2.0 original tire - 1.8 this tire.
i am happy)))
40000 miles next exchange)))
I also thought about buying TOYO. But after looking at the price and seeing how my previous tires died after 40,000 miles. I decided on this type of tires. I'm happy. Now I can safely drive in snow and wet weather( snow rated (3 peak) ))
Ford F-150 Lightning Installed Toyo Open Country AT3 EV 116 T XL All-Terrain Tires 20231208_141513
Ford F-150 Lightning Installed Toyo Open Country AT3 EV 116 T XL All-Terrain Tires 20231208_141528
Ford F-150 Lightning Installed Toyo Open Country AT3 EV 116 T XL All-Terrain Tires 20231208_144549
Ford F-150 Lightning Installed Toyo Open Country AT3 EV 116 T XL All-Terrain Tires 20231208_144551
Ford F-150 Lightning Installed Toyo Open Country AT3 EV 116 T XL All-Terrain Tires Screenshot 2025-01-27 200451
broncoaz
Cape Cod, MA
Noise is the most important tire variable to me; should I buy Toyos?
