Keyboard fails to show up for Backup Passcode
Lightning Bronson
Jansen
Greater Toronto Area
F150 Lightning Lariat
Snow Removal, Landscaping
Good thing I was at home and *just* wanted to try if it worked. The backup passcode is kinda useless if it doesn't work, no?
Ford pls fix
I don't understand why the video uploaded in that orientation. Oops.
jetfixr1
Anthony
Atlanta
2023 F150 Lightning Lariat ER
This happened to me as well. The UI is terribly slow and tapping it like that will just make it freeze. Try starting it with the backup code but only tap the screen once and wait. My keyboard took around 20 seconds one time.
Sync reset usually solves this and similar issues. Hold volume down and skip forward on the steering wheel until the screen turns blank and resets. I'm not sure if you can do a Sync reset if you also need to enter a backup pass code.
NCA Lightning
Utah
2022 Lightning
Same thing happened to me. I use PAAK exclusively, and have for 2.5 years. I’ve had to enter my passkey 3-4 times when my phone has died. You have to touch the screen once, and wait 30 seconds. It feels like an eternity when the panic that you’re stuck sets in. The keyboard always comes up eventually though.
Whitewater64
Scott
Palm Springs, CA
MY 23 F150 Lightning Lariat ER Max Tow Star White
Singer/Conductor
I also had keyboard unwilling to show up for a time. Called Ford, actually spoke to a tech who knew what she was talking about and guided me through the Sync reset. It has worked without fail since then.
jetfixr1
Anthony
Atlanta
Worked fine for me.
