Looking for rear lightbar removal instructions.
Pswag115
Peter
Atlanta, ga
'21 Mach E, 22 Lightning Lariat ER
I'm looking for instructions to remove and replace the rear lightbar on my '22 Lariat. I've got 51,000 miles and a inop light bar on the tailgate, dealer says my vin is not part of the recall even though i have water in the light bar. I bought a used one off ebay and have worked on cars as a hobby my whole life, but this looks like a bunch of body clips to break the tailgate down till i get to the light bar fasteners.
Anyone know of any articles or videos on this subject?
Thanks
Did you check your VIN on Ford.com to verify that the dealer is correct?
Did you ever receive a letter about the lightbar recall? It's been a while now but I was under the impression it was all of the early models.
Does the Ford website say anything about your vin?
You might want to read the main thread if you haven't already.
Here are removal / re-install instructions:
christopher
f150 2022 lightning
contractor
I drilled four holes in my light bar at the bottom corners and center. This allows the water te escape. NO MORE FOG. it will probably void the warranty but if the leds are still working it will save you a ton of time.
Lytning
Georgia
I suggest calling the Ford BEV Team. This is a safety recall for moisture in the rear lightbar. If you have moisture in the rear lightbar, @Ford Motor Company should fix it, regardless of VIN. If they refuse to do so, I suggest filing a safety complaint with NHTSA.
ZSC100
Zach
Tulsa, OK
Electrical Engineer
Lytning is 100% correct, your dealer is not acting in good faith on this issue. Moisture inside the rear lightbar is a known defect and it IS definitely covered so long as there is no owner caused damage. Even outside warranty this WILL be 100% covered by FORD. Tell you dealer to call the BEV team on your behalf. For me the BEV team gave me an extended warranty to cover a lighting issue b/c I was out of warranty and that's the way they wanted to handle it financially.
Pswag115
Peter
Atlanta, ga
I did a complaint with Ford (not Bev team though) and NHTSA in Jan when i noticed light bar was not working. I did not schedule a service with the dealer after calling them about the issue because i have no intention of paying $3000+ to have them fix it.
I will reach out to the bev team, cant hurt at this point. IDK if owning a Lightning and a Mach E will help my cause with them.
ExCivilian
'22 Platinum
What was your final resolution? In my case, the light bar was replaced in 2023 so the part itself is considered to be out of warranty and my truck is out of warranty. My Lariat had to go through two replacements before Ford revised the part but it was within warranty.
BEV team told me they would work with the dealership to offer financial "assistance" but that wouldn't cover the entire cost of repair. My Platinum isn't coming up under the recall I guess because the replacement was already satisfied.
Pswag115
Peter
Atlanta, ga
Crickets from Bev team, Ebay light is still in my garage, and I just recieved the replacment platsic trees for the tailgate trim.
May do this project this weekend.
ExCivilian
'22 Platinum
I tried this afternoon and it was a total PITA. I couldn't figure out how to get everything unbuttoned. There are at least several grommets that would have to be broken off and are not reusable. Whenever I see that in the instructions I tend to think it's whatever but these really do seem to be one-time use only.
I think you have to remove the outside skin of the tailgate above the light bar but I can't figure out how it pops off. If you figure out how to do it LMK because I'm curious what I'm missing. The instructions didn't seem to match what I was looking at after I removed the inside plastic cover.
HeavyD
2024 F150 Lightning Platinum
Hi All. New to the forum and posting in general. I need to replace my rear light bar (2024 model not covered under recall). I the lightbar instructions are easy to find. I can't though find a video or the instructions to remove the "tailgate molding" that covers the top part of the light bar. See attached. I'm looking for instructions from the Workshop Manual , a video, pictures etc. on how to remove the clips/piece. Don't want to create a bigger issue than I currently have.
Ford F-150 Lightning Looking for rear lightbar removal instructions. Lightning Tailgate Moulding
HeavyD
Thanks for checking this out. It appears to be several (maybe 8) plastic clips. I damaged one trying to remove them so I'm reluctant to get too aggressive and end up with a broken moulding piece on top of a broken light bar. I'll try to play with is some more - just wanted to be sure I was missing something obvious in the WSM.
