Gerstein1989
Alexander
Barrie, Ontario
2024 Lightning Lariat
Plumber
That made no sense to me, and when asked in the comments to the video, he states it's because those wires "provide no power". Very confusing.
I ordered the harness and emblem so I’m gonna plug it in first before I do anything. Maybe his harness was just defective. I’ll post here to let you guys know what happens. But either way I think the wires will have to be extended because the harness was originally designed for an ice f-150.
NeuroDawg
Puget Sound, WA
'24 Flash ER (previously '23 XLT ER)
It will definitely need to be extended. My understanding is it plugs into the right headlight. You'll need to extend it back to the fuse box and then up into the frunk lid running forward to the grill. In the Q&A on the Putco site, they say the emblem comes on with the DRLs. That's also odd to me, because then the emblem would go off when the headlights come on and the DRLs go off.
Looking forward to your testing.
NeuroDawg
Puget Sound, WA
Aftermarket is 6500K and I believe Fords is 4000K
FYI, 6500K and 4000K are measures of the temperature of the light (i.e. the color), and not brightness. They both appear to be 6500K in the videos I've seen, as that temperature is considered to be "cool white", while 4000K is warmer (i.e. more yellow), like an incandescent bulb.
Gerstein1989
Alexander
Barrie, Ontario
Plumber
so with the harness you don’t need to go to the fuse box. Also I think it works on either headlight. My plan is to plug it into the drivers side headlight. There is a rubber housing on that side that goes from the frunk to the hood so I might be able to fish my wires through that for a cleaner install. I will post back here with results. I’ll take pictures as well. Everything is coming this week so most likely I’ll get it installed this weekend.
NeuroDawg
Puget Sound, WA
Yes. I meant back near the fuse box, just to get it up into the frunk lid. Now, I did see a Q&A on the Putco site that said it has to be plugged into the driver's side headlight. I wish Putco would publish their installation sheets for these things so they could be reviewed prior to order.
Gerstein1989
Alexander
Barrie, Ontario
Plumber
ya they aren’t good like that. Plus when you call and ask questions they don’t even know. They told be the harness wouldn’t work, saying the lightning uses a different headlight harness lol. Also they don’t ever plan on coming out with a harness for our trucks as they say it’s not worth it for them to make it.
Aminorjourney
Internet
vehicles that go
The original ICE F150 harness is what you end up with. The Pinout is different. Martin explains how to tap different wires because on the lightning, those are the ones used for power.
Gerstein1989
Alexander
Barrie, Ontario
Plumber
I’ve installed the emblem. I will do a write up in the next couple weeks. So you do have to swap out the wires on the harness. Using the harness is a lot cleaner than the fuse box. As well I will be adding the camera washer back and the parts guy found me all the parts I would need. The most important part though is the hose which I would rather a factory one then parts slapped together at Home Depot. This is the house part number if anyone is interested. I’ll post the rest of the part numbers when I do my write up.
Ford F-150 Lightning F-150 Lightning LED Ford Emblem Swap. Step by Step Installation DIY Video. IMG_0407
FastCote
Ben
Columbus OH
2022 MachE GT, 2022 F150 Lightning Lariat, 2022 F150 Lightning Platinum
I purchased my second lightning and it already had the emblem installed and wired. Looks like they used fuse 48?? I think when you turn on the heated seats in the back the combination of emblem and seat heaters blow the fuse.
What's my easiest "rejigger" from here? I really don't want to rip out the existing wiring and rebuild a harness. Should I just move to fuse 10 like I've seen others do??
SpacemanSpiff
Jayden
Huntsville, Alabama
2023 F150 Lightning Lariat ER, 2024 Mustang MachE Premium ER
I'm wondering how this all worked out from the driver's side headlight back through the existing wire loom. This does seem like the cleanest approach to me, and has the potential benefit of possibility avoiding radio interference since the routing is on the opposite side, away from the antenna.
Gerstein1989
Alexander
Barrie, Ontario
Plumber
I was gonna do a write up but have been so busy. I swapped the black and red wires like the video said and then routed the wire through the rubber wire harness housing on the frunk lid that way all the wires are hidden. I had no interference with the radio as everything was done through drivers side.
SpacemanSpiff
Jayden
Huntsville, Alabama
Perfect. Thank you, sir!
Aminorjourney
Internet
vehicles that go
We're doing a video on this later this week but...
We did the washer upgrade too, and were able to route the tubes through the oem route - and the cable followed it. Plugged in the cable on the passenger side, which was difficult, but just about doable.
Ford F-150 Lightning F-150 Lightning LED Ford Emblem Swap. Step by Step Installation DIY Video. IMG_7483
Gerstein1989
Alexander
Barrie, Ontario
Plumber
I did the camera washer. You can just buy the oem hose and everything is plug in play. No modifications needed. Also it’s better to route wires through drivers side as there is no radio interference that way and a cleaner install as there is a rubber harness housing and you don’t see any wires
Aminorjourney
Internet
vehicles that go
Oh, there's no interference on this side for me - and I made my own loom case ;)
