Ford F-150 Lightning Tow Report: Ford Lightning vs. 4500lbs of Raccoon-Covered History SmartSelect_20250412_185000_Gallery
Today’s adventure involved my Lightning, a U-Haul car hauler, and a 40-year-old Oldsmobile that’s been sitting so long it’s now more raccoon habitat than car. It came complete with a small block engine, four flat tires, and a generous coating of nature’s graffiti. But hey, the price was right.
We headed north 130 miles with the empty trailer—full dual axle, probably close to 2,200 lbs. The trip took 2.5 hours, coming out of a warm garage but cruising in cold air around 30°F. The Lightning averaged between 1.5 and 1.6 mi/kWh for that leg, which I consider solid given the weight and wind drag of the hauler. Avoided the highways so for other than a few little bits speeds were 55 and below.
The return trip was the real test: same distance (different route, but comparable roads), now with 4,500 lbs of vintage steel and raccoon residue strapped down. We drove just a bit slower—though still ending around the same time, 2.5 hours. I was expecting a noticeable hit to efficiency... and it didn’t happen. The truck averaged between 1.4 and 1.5 mi/kWh. Practically identical to the unloaded leg.
We made one 50-minute stop to charge and grab lunch (Arby’s, because nothing pairs with a barn find like questionable roast beef). During the drive, I kept an eye on the trip meter: On the outbound trip, 6% of energy usage was tagged for outside temp with a few percent for climate. On the way back, with temps in the low 50s, losses were down to 5% for temp and 0% for climate—cabin heat wasn’t even needed.
Elevation gain/loss wasn't a major factor either—despite heading north, the pickup point was actually at a slightly lower elevation than our starting point. So no real downhill advantage there.
Bottom line: the Lightning handled the load better than I expected. Efficiency with a full trailer and car wasn’t dramatically worse than running empty in cold air. It’s nice to see some consistency—and even nicer when it involves less math and more hauling.
gregoryhcain
Gregory
Steilacoom, WA
Toyota 4Runner, Nissan Pickup
Physician
I get about 1.5 m/kWh towing my 17’ 3500 lb boat motor trailer so that sounds about right
The Olds looks great from 50 feet!?
For being nearly 40 years old it's pretty darn good from 10 feet too!
True one owner barn find, buddies grandma was driving it up until 20 yrs ago, when it was parked in a pole barn. 40k miles on it. Minimal dings or dents, some rust but no rot.
Lots of racoon shit though....
What engine is in the Olds?
Electric Messiah
Davis
Massachusetts
F150 Lightning Lariat ER
Hmmm… raccoons… questionable roast beef…
Nice project! What are you going to do with it?
I wish I could say big plans but honestly I'm just going to clean it, get it driving, and sell.
They are fetching good prices right now and I got it for an absolute steal. It's a cool car, but not MY cool car, so it will fund other projects.
B177y
Olympic Peninsula, WA
It the Olds a Delta 88?
My first car was my dad's Delta 88 diesel. I wish I still had that land boat. 300k+ miles split between 2 GM diesel engines. It was totally underpowered, naturally aspirated (no turbo), and belched black smoke. The mileage and the fuel savings hooked my dad during the 70' and 80's gasoline inflation. Perfect starter car for me - beater, slow, and BIG. It finally went away once we moved to the mountains (6200') from sea level as the thin air made the engine "performance" non-existent. Ah, the memories....
I was just surprised the efficiency was so close.
1.6mi/kwh for a 2200lb empty trailer and 1.5mi/kwh for the same trailer plus another 4500lbs and an aerodynamic brick sticking up.
Cutlass Supreme in this case. Still trying to figure out exact trim.
Ford F-150 Lightning Tow Report: Ford Lightning vs. 4500lbs of Raccoon-Covered History 20250413_140851
Ford F-150 Lightning Tow Report: Ford Lightning vs. 4500lbs of Raccoon-Covered History 20250413_140902
Ford F-150 Lightning Tow Report: Ford Lightning vs. 4500lbs of Raccoon-Covered History 20250413_141016
Ford F-150 Lightning Tow Report: Ford Lightning vs. 4500lbs of Raccoon-Covered History 20250413_141000
