locks66
Will do! Thank you!Have the tech look at step 11 on 24B56.
Does this apply for 12 inch center display screens as well?Have the tech look at step 11 on 24B56.
No. It's only for the larger screens.Does this apply for 12 inch center display screens as well?
Yep, just dropped mine off yesterday to have the 360 postage stamp fixed.Yours is normal. The only issue is on 22's where the dealer didn't follow directions so they're left with the black box around the image until it's either fixed in FDRS or FORScan.
I’m still stuck on the new power steering feel after getting this update. I’m really not liking how loose it feels and how bumps in the road seem to pull the wheel away from center unlike how it was before. Is this experience similar to others? I also had the front control arm bolt/nut recall looked at the same time and the dealer said it was fine, so I’m assuming the new steering feel is from the reprogrammed modules in the front sensor CSP.Power steering module gets reprogrammed as well. I noticed it almost immediately when I picked it up. Less of a center feel and the camber of the road pulls the steering differently. I’m sure I’ll get used to it but I liked the old power steering boost level.
I wonder if the FORScan gurus can find a setting to tweak???
This is what I’m experiencing.I’m still stuck on the new power steering feel after getting this update. I’m really not liking how loose it feels and how bumps in the road seem to pull the wheel away from center unlike how it was before. Is this experience similar to others? I also had the front control arm bolt/nut recall looked at the same time and the dealer said it was fine, so I’m assuming the new steering feel is from the reprogrammed modules in the front sensor CSP.
It turns out that my LVB was trashed by the 24B56 parking sensor update. Although the cell voltage could be raised by prolonged charging, the battery capacity had been trashed, as revealed by the low-capacity ratings that Car Scanner was giving me after the update. The dealer replaced my LVB at no charge, and everything's back to normal.However, I think the problem is not that the update trashed the LVB capacity (my dealer says they always use a power supply backup in flash programming, but the CSR couldn't tell me how big a rig!). If I read the LVB voltage across the jump points in the frunk, I get readings like 12.57V, 12.64V at 65F to 72F. That suggests the LVB is charged to 80% to 90%. Seems more likely that the update screwed up the BMS or its communication with other modules. Rather than trying to cure it myself by disconnecting the negative LVB terminal, etc., I'm just going to bring it back to the dealer this coming Thursday and let them figure it out.
So I feel like I’m taking crazy pills but the weird loose steering feel has seemingly corrected itself for me after about a week or two of driving. It was definitely different right after the front sensor CSP programming was done and I hated it. But I’ve noticed it is back to the normal firm steering feel. So either I’m losing my mind or there’s some kind of relearning process that happens with the steering after this particular CSP is done.This is what I’m experiencing.
I’ve seen on F150 ICE forums about a few settings in the PS Module that can be changed with FORScan, one specifically dealing with return to center. I have not played with this and haven’t researched fully yet.
Experiencing this as well and has significantly changed the driving feel. The ratio of the steering has changed, giving it a much lighter, faster, and less steady feel, especially at lower speeds. The weight of the steer was definitely heavier and less touchy before, strongly preferred it.I kinda miss the heavier steering feel
Had a moment like this, but it was because of low morning temps (around 30 degrees), cold slowed the speed of the steering. Got back in the truck at lunch (around 75 degrees) and it was the same loose steering. The warmer the temps, the greater the perceived loose feeling in the steering.So I feel like I’m taking crazy pills but the weird loose steering feel has seemingly corrected itself for me after about a week or two of driving. It was definitely different right after the front sensor CSP programming was done and I hated it. But I’ve noticed it is back to the normal firm steering feel. So either I’m losing my mind or there’s some kind of relearning process that happens with the steering after this particular CSP is done.
And I feel like the lane centering isn’t as great as it was before. Anyone else?
My lane centering doesn’t seem to be affected as far as I can tell. It has been colder here in MA though so when it warms up again I’ll pay attention to the steering feel and see if that changes anything.Had a moment like this, but it was because of low morning temps (around 30 degrees), cold slowed the speed of the steering. Got back in the truck at lunch (around 75 degrees) and it was the same loose steering. The warmer the temps, the greater the perceived loose feeling in the steering.
Was pulling to the left when I left the dealership. Seemed to improve and is less of an issue right now than the change in steering feel.And I feel like the lane centering isn’t as great as it was before. Anyone else?
Here's hoping you're right and I'm wrong!My lane centering doesn’t seem to be affected as far as I can tell. It has been colder here in MA though so when it warms up again I’ll pay attention to the steering feel and see if that changes anything.
I’ve had a similar experience. I chalked it up to the freshly rotated tires wearing in a bit, but now that you mention it it seems possible the steering feel is changing a bit over time?So I feel like I’m taking crazy pills but the weird loose steering feel has seemingly corrected itself for me after about a week or two of driving. It was definitely different right after the front sensor CSP programming was done and I hated it. But I’ve noticed it is back to the normal firm steering feel. So either I’m losing my mind or there’s some kind of relearning process that happens with the steering after this particular CSP is done.
@KHines, @MountainAlive, @Cvh8601 -I’ve had a similar experience. I chalked it up to the freshly rotated tires wearing in a bit, but now that you mention it it seems possible the steering feel is changing a bit over time?
