Canopy Bed Security Cameras
Jamchampnate
Nate
Utah
Ford lightning 23’ Lariat
If you are using firmware version 10.50.0, send them an email, the same thing happened to me on this version and the battery was not able to keep up. The company recently pushed out 10.50.4 and the battery issues went away.
I am not 100% sure that the battery issue was caused by the .0 firmware. At the time, we pulled all of the cables and reset them just to make sure everything was tight.
I’ll need to check this out. Mine died about 3 weeks ago and it’s too annoying for me to want to pull the whole thing out and charge it.
Can I just plug it into one of the USB c chargers in my car to charge it without taking the whole stupid thing out and apart?
Scott Libre
3rd Planet
Mach e
Space Lazer Repair Technician
We tried that, but a charge would never start, so we had to bring it back inside for a few hours.
Jamchampnate
Nate
Utah
Damn. Thanks for the heads up. I’ll bring the box inside.
Anyone hear any updates when this will end and the what it will look like ever beta?
MidAtlanticLightningClub
F-150 Lightning Lariat ER
I have firmware 10.50.4, so that's not it.
I drove over 3 hours Sunday. It's now Tuesday morning. I haven't driven since my return and I'm having to tear the box open again to bring the battery inside for a charge. There was only one activation during that time and I don't live stream my truck bed. This is a real pain.
I'm replacing the screws that hold the box closed with velcro.
If they can't fix the charging, I wouldn't recommend a Canopy unless someone drives their truck every single day.
Scott Libre
3rd Planet
Mach e
Just curious, did you reseat the diagnostic port that powers the unit?
Do you mean the OBDII connector? I had tested it when I had issues with the initial installation last month but haven't reseated it since then. I can unplug it and plug it in again but the rest of the operation seems fine.
boggle
CT
MY23 PRO
Check the USB-C power cable from the OBD II going into the box. The way they keyed the barrel terminals is idiotic and provides no positive confirmation of a connection. One of my complaints in their surveys, why they avoided using something proven like an M12 connector is beyond me.
Scott Libre
3rd Planet
Mach e
Yes, the OBDII connector. The first time we had battery stability issues, we reseated this port and it took care of the problem.
Jamchampnate
Nate
Utah
All right, I manually charge my battery and plugged it back in and it’s got the latest update so we’ll see how it goes. I re-seated all of the plug terminals so if it dies again, I’m just gonna leave it dead until they ask for it back or they don’t, but it’s kind of a pain and not really worth it.
I recharged my battery, reset all the connections, and rebooted the system. We'll see if it makes a difference.
Keanen
Keanen
MN
2023 F-150 Lightning
Software Engineering
Here it is. Works well for powering the Canopy cam and data for ABRP Premium.
I don’t see a link to the splitter in your reply. I don’t know if the forum is cutting it out, but maybe you could offer the product name on Amazon?
thank you!
Hammick
Somewhere in MT
thank you!
Screenshot attached.
Ford F-150 Lightning Canopy Bed Security Cameras Screenshot 2025-05-10 at 9.18.07 AM
Jamchampnate
Nate
Utah
Anyone heard any updates on when the beta will actually end and what the plans are afterwards?
Keanen
Keanen
MN
unless I miss something, I think I’ve only had one survey to fill out since I received the unit. Have you guys had more engagement?
