Good video of finding your factory door code!
jallen
2009 F150 XLT / 2023 Ford Lightning Pro
I feel like this has been asked many times, and usually the person is pointed to finding the card in the glovebox or somewhere else in the truck. I have to admit, though, I had not seen this method shown and demonstrated clearly. Tim is a great resource in the Ford Community!!
Saw this and almost posted also. Tim explains this is new for 2024's. [Edit] I'm not sure this works for '22 and '23. Works for 22's and 23's also.
jallen
Saw this and almost posted also. Tim explains this is new for 2024's. I'm not sure this works for '22 and '23.
Ok, my bad if it’s only for 2024s. Didn’t watch close enough obviously.
Well he said it was for 2024 but I researched and it applies to older models as well.
Here is the process (requires 2 keyfobs):
  1. Remove bottom cup holder liner to expose emergency keyfob slot
  2. Put fob #1 fat end down into slot. Truck should be off.
  3. Press Start WITHOUT foot on brake.
  4. After truck starts (dash message "Accessory mode is active") turn truck off.
  5. Put fob #2 fat end down into slot.
  6. Press Start WITHOUT foot on brake.
  7. Dash will display master code for the truck.
Once Step 3 is started you have 30 seconds to finish.
Backwardsfish
Pat
Vancouver, Canada
Lightning Flash (previously Mach E)
I tried this for a long time and finally his note of “big side down” and “all in less than 30sec” worked magic.
Again,
KEY BIG SIDE DOWN
ALL DONE IN LESS THAN 30sec.
broncoaz
Cape Cod, MA
My dealer sales guy followed this procedure when I took delivery yesterday.
Gman
Ken
Biloxi, MS
2022 Ford F150 Lightning Lariat
Retired Developer
This procedure did not work for my 2022 Lariat SR. When I removed my Phone As Key (PAK), the door combination was reverted back to the default factory code which I didn't have. I went to Ford and they used an electronic device that plugged in under the dash. And with some software on his phone, he was able to provide me the default factory code. Took about five minutes.
I just tried it on my 2022 Lariat ER. It worked for me. It showed the 5-digit Factory Code, not my programmed door code. However, the code was different than the Securicode that was printed on a wallet card I found in my Owner packet.
EDIT: While the SecuriCode and Factory code were "different", they were the same key presses. For example the digit may have been "1" or "2" but they are the same key since each key has two numbers on them, i.e., the code "13579" is the same key press sequence as code "24680".
All codes unlocked my door - personal code, SecuriCode, and Factory code.
Ford F-150 Lightning Good video of finding your factory door code! Factory keypad cod
This message was cycling though the dash display along with "Full Accessory power active" and "Key battery low Replace soon".
Robert1380
Robert
2025 Ford F-150 Lightning Platinum
Retired law enforcement
Doesn’t seem to work on the 2025. I been trying for the last 90 minutes
Your 2025 does not come with the factory-installed integrated keypad that this thread is describing. Ford dropped that feature in 2025 and now offers a dealer-installed stick-on keypad that is battery-operated.
I do not know how that one works - it could be that it operates differently. The 2025 Owners manual dropped all mention of keypad programming. You may need to search for dealer-installed keypad instructions.
Robert1380
Robert
Appreciate ya!
RLXXI
3rd rock
Automotive Technician
When I had mine connected to either Forscan or FDRS, don't remember which, it showed the keypad option turned off so I turned it back on as I'm going to install the factory hard wired keypad. Have the parts already, just waiting for the weather to cooperate.
I noticed the wiring for the keypad is still inside the door waiting for a keypad to be plugged into it. Then I'm almost certain the key code can be obtained via the 2 key method.
Pic inside door showing keypad harness capped and attached to the door brace.
Ford F-150 Lightning Good video of finding your factory door code! keypad harness
Ford F-150 Lightning Good video of finding your factory door code! keypad pillar trim
