Truck smells like a catbox on hot and humid days
2wheeltraveler
Austin, TX
2022 F150 Lightning Lariat Rapid Red
I've read dozens of posts about musty and other smells and all were fixed by cleaning the condenser coils, and when they did come back (nearly everyone said it did), it was after 6 months or longer.
My situation seems to be different. I first paid to have the truck fully detailed by a 3rd party ($400 it was due for a good cleaning) and that didn't fix it, then the dealer performed an HVAC clean ($200) that resulted in some foaming in the vents and such. It smelled nice for a day and the smell returned.
Now they have a technician looking at it and they can smell it (they described it as musty, but you have to trust me when I say there is a distance difference between a musty/moldy/mildewy smell)
This has been getting worse for over a year, only to subside during the colder months.
Anyone else have a similar situation and can offer guidance? I'd hate to keep paying to investigate things without formal resolution... this could get expensive but it's embarrassing to have people get into your vehicle and ask what the smell is.
PS. I did notice that a neighbor a block away leaves their garage door open and they have a couple cats that come and go. I'm wondering if they may be going up under the truck and leaving scents that are somehow coming in through the vents.
The outside air intake is on the passenger side between the frunk & windshield, if they're napping or marking on top of your frunk that could be an issue.
As far as the mold smells, it's been a nature of the Ford HVAC system for decades, all my F-series trucks eventually develop this, it's probably worse for folks in the south having a longer AC season than folks in the north like me.
My A/C gets used between March and November, haven't had this problem. Only time it smells bad is when we drive by a dairy farm or someone who has clearly neglected their exhaust system. These are usually rectified by switching to inside air. ( Note: Inside air circulation does not say on while using auto )
That said, humidity is in the single digits most of the year so that may have something to do with it.
kf59
Ken
4$a7Yaofbfutc
Cats love sardines. Get yourself a live trap and see what you catch. Fair warning however, raccoons and skunks also enjoy sardines.
2wheeltraveler
2wheeltraveler
Austin, TX
Shop foreman went through the truck, found no sign of critters leaving presents or other activity. No water penetrations found. Blew out the (newish) filter. He personally re-did the clean, this time there wasn't much of the foam coming from the vents as before but the smell was gone. Will wait a few days and see, will drop updates here if it comes back.
They didn't charge for this trip or loaner, no haggling was needed which I really appreciated. So far Covert Ford in Austin is handling it well.
johnkelley1
Maryland USA
F-150 Lightning, Tesla Model S
Systems Engineer
Thanks for posting this. I thought it was only me. My truck lives outside in my driveway and it sometimes smells like a cat litter box / cat urine. There are no cats getting into my truck as there are few in my neighborhood and I have a video camera that covers the driveway and I have reviewed many hours with no animals near my truck overnight. I guess I will have to try the $200 dealer HVAC clean, but I am wondering what is causing this unique smell? I have had F-150s for over 40 years and they do get musty, but not like this. This is unique. It may be the same humidity issue, but it is a different smell than I have ever smelled before. Almost like some sort of chemical smell. Cat urine is what comes to mind, but I am as certain as I can be that it is not related to actual cats. I do park near a dogwood tree and I suppose it's possible that tree droppings are getting into the fresh air intake ducts. But somehow I feel like it is related to HVAC and maybe a seal or refrigerant smell?
Thanks everyone for considering the options. I have a 2023 Platinum Lightning with 7000 miles. Does not have the new heat pump but rather the original system.
Thoughts?
Thanks for your reply.
Deleted member 15277
Guest
I actually had cat box smell after a cat pissed on the rear floor. No amount of cleaning oxy clean etc helped. But I bought a cheap air ionizer from Amazon and let it run for 6 hours with the truck on recirculation. THAT did the trick. Been a year and that smell has not returned.
You might consider the possibility that there is a leak of coolant somewhere, maybe a bad seal on a compressor or pump. The coolant can smell sort of musty.
One really hot day (over 100F) here last summer I parked for 15-20 minutes on an open asphalt parking lot and when I came back to the truck I started it and turned on the MAX AC and got a blast of musty smelling air from the vents - actually to my nose it smell like AC coolant. I turned off the AC and opened the windows. Drove home, parked in the shade, and a few hours later tried the MAX AC and no bad smell anymore.
When I looked it up I found that AC systems can have intermittent coolant releases when there is a high pressure due to a temperature issue that the compressor can't handle and coolant can leak around seals, that's a summary as I understand it anyway.
So maybe have your heating and cooling system pressure tested for coolant leaks?
good luck
Ragman
We have this issue in one truck of five, it's had it since the day I picked it up - no issue in winter but as we head into spring now its "back". Dealer has been through it pressure checked AC system, etc can't find a reason. Currently have a can of 24 Hour Microban Sanitizer sitting on my desk with plans to fog it... My guess is a drain issue potentially, I haven't went searching or left it with AC running on pavement to cheque. Understand it's in the wheel well - may find a straw off a WD40 can and spray sanitizer up the drain line to blow it out/kill anything in there.
2wheeltraveler
2wheeltraveler
Austin, TX
So far I’m a week in and the 2nd EVAP clean they did this time seems to be holding. If it makes it another week I may declare victory…
2wheeltraveler
2wheeltraveler
Austin, TX
After first dealership visit, it came back right away after the fragrance of whatever was in the vents wore off.
I took it back and they had their "best guy" work on it, and that seems to have tamped it down significantly, but it's still present every other trip or so, some worse than others.
I'm already a bit nose-deaf to it but folks getting in the car definitely notice it.
I'm concerned this is going to be a money pit if I keep trying to get it fixed by the dealer so not sure what my next move is yet. I plan to hang onto the truck for a while still and really need root cause fixed.
RLXXI
3rd rock
Automotive Technician
Take out the cabin air filter and close the panel, with the ac on high, system on recirculation, spray Lysol disinfectant into the air intake under the dash near the blower fan.
Put a towel on the floor as it will drip while spraying.
Leave the cabin filter out, put the system on fresh air and spray the cowl between the frunk and the windshield on the passenger side, don't be stingy, soak it good.
Leave the system running for about 5 mins then put the cabin filter back in.
I <3 My Lightning
What ever the source or past vehicles, some are just smellier than others. The worse was my Yukon Denali and had to clean both the front and cargo evaporators, at least twice a year. It was really bad when it was brand new and the dealer programed the blower to run to help dry the HVAC system after the vehicle was off. That helped a tiny bit... Still had to clean the system twice a year.
I noticed the lightning will get smelly if I don't run the AC regularly and as others noticed the AC resets back to on with a key cycle. I will say that is on purpose by ford. Otherwise there will be a ton more complaints. Freeze over the evaporator fins and defrost regularly and let drain is a strategy to keep the system clean... That's how the Samsung mini split I have is designed for its cleaning cyle.
Our kia ev6 has an automatic AC evaporator drying cycle, (has a heat pump as well), and it cranks that fan full force and it's for a bit of time. This is the only vehicle that I never had an issue with a smelly HVAC system. But the interesting part of the design is the filter is high up in the the middle of dash and accessed inside the tiny frunk. Any smelly HVAC system has always been with the cabin air filter in the passenger foot well behind the glove box.
So years ago I use to use something similar to this...
https://www.autozone.com/cooling-he...cleaner&cmpid=SPL:US:EN:AD:NL:1000000:GEN:pdp
The amount they give you is not enough for bigger vehicles. So for a couple dollars more I discovered and switched to this... I was glad I kept some of the past hoses...
https://www.walmart.com/ip/Frost-Ki...7?classType=REGULAR&athbdg=L1600&from=/search
