Console to column shift swap mod?
s_c
New England
2023 Lightning Owner
We are in business (not exactly, if you ask my wife)
Her first response is that it looks like a downgrade. She cheered up when she realized the umbrella could sit on the floor between the seats. Wait till she can put her bag there!
We’re still without the associated steering column shroud, trim pieces for the dash console, the center seat rear cup holder unit, and definitely going to add the flip out floor cupholder.
Id also like to swap out the cupholder plastic in the flip down seatback for a version with 3 or 4 cupholders. The shallow rectangular recess isn’t useful. I haven’t seen such a thing but will be looking (update - I see from @kdkool post #56 that seatbelt stuff is going on inside seatback at the location of that recession so this plan is probably out)
Forgive the mess and rain..!
Ford F-150 Lightning Console to column shift swap mod? IMG_3092
Ford F-150 Lightning Console to column shift swap mod? IMG_3094
Ford F-150 Lightning Console to column shift swap mod? IMG_3097
VTbuckeye
Vermont
Very nice. One of the other cars that I drive regularly has a column shifter. I have now swiped at air trying to shit into drive on the lightning and activated the windshield wipers on the Volvo xc40. Column shifter just makes sense, is always out of the way and works great.
Yellow Buddy
Smart Ass
What did you do for the seat belt for the middle seat?
You swiped at air trying to what???
VTbuckeye
Vermont
Switch from reverse to drive. On my Volvo EX90 the gear selector is on the right side of the steering wheel (opposite the turn signal stalk). Drive is down, reverse is up (the stalk returns to the neutral position after actuation).
Haha, no, read what you typed. The word after "swiped at air trying to ..." :)
(Hint: It wasn't "shift")
VTbuckeye
Vermont
Oops. I ducking hate it when my ducking phone ships the bed when it comes to properly censoring me.
s_c
New England
i believe seatbelt and buckle receptacle are integral to seat. In the case of my donor I believe it has been cut so will be sourcing that. No one sitting up there for now
kdkool
Atlanta, GA
2023 XLT Lightning / 2023 6.7L Lariat F-350
The seat belt for the center bench seat is all packaged with the seat unless the bench seat originally came from a single cab (the center seat belt for the single cab is on the rear back wall ).
The single cab center bench seat will also be missing the rear cupholders / trim panel for USB / 12V outlets.
sen7inel
NJ
Lightning XLT ER, Model Y
Been following this awesome project for a while now @s_c . Curious if you were able to compile a list of the missing trim pieces / get the interior completely together.
s_c
New England
I myself have not gotten to it but if you look at link in previous post (#58) PulpoGrande did it from the outset and listed all the parts
GROWINUP83
Jorge
Nevada
2023 F150 Lightbing Pro
HR
Hi all
quick question on jumpseat install….. What wiring will or is needed for the transmitter under cupholder?
s_c
New England
Hi all
The one that detects the key? I can say... I have it in that cavity beneath the jumpseat underseat storage where the airbag module etc is. It mostly works, but does not detect key reliably when key is up on the dashboard in the center tray. I believe I'll be able to move it to a better position without having to extend it but won't get to look at it for a while.
lister coggs
Lister
Barrie, Ontario
2022 Lariat SR
Is there a simple, inexpensive, (potentially ugly) way of connecting a rotary shifter without any center console for a temporary jump seat conversion?
Not looking for OEM aesthetic or ergonomic, just the absolute easiest way of having a reversible jump seat installed in the center to allow the truck to seat 6-people temporarily, while still being able to shift the vehicle.
Initially, I was going to go with the infotainment column shifter route, but their conversion kit just extends the shifting harness in the center console, which wouldn't be viable if the whole objective was to remove the center console and replace it with a jump seat. All of the rotary dial conversions I've seen just extend the center console cabling as well.
Use case is just a two-week road trip where we'll be seating 6 people and ideally avoid two vehicles.
s_c
New England
I would say, for the level of simplicity it sounds like you're looking for, probably not. The complexity isn't majorly the connector to the shifter, it's that a lot of the wiring is tied into that center console. Once you remove the center console and free the wiring, it's not difficult to relocate a rotary shifter but it's not trivial to uninstall the console and put it back in.
