MrLoganRoss
- First Name
- Logan
- Jul 28, 2024
- Seattle Washington
- '23.5 MachE GTPE & '24 Lightning Lariat
Maybe a collective amount of feedback may help them to fix their testing methodology related to electric vehicles. This is not an attempt to claim that the F150 meets its EPA target. However, their methodology is inherently flawed, which makes the F150 look pretty bad. The article is here:
https://www.consumerreports.org/car...s-models-that-beat-epa-estimates-a1103288135/
In terms of the point I am trying to make Make:
If you are going to test on the highway, you should use each carās 100% highway rating (which they allow you to calculate or āpersonalizeā at fueleconomy.gov). You would then expect the results to be lower if you test at a faster speed than the EPA calculation is based on. I would expect Trucks to under perform the EPA rating on a 100% highway test at a faster speed than the EPA rating is based on. Therefore I think this article is a bit flawed. For example, the actual F150 lighting EPA rating is 302 mile range for all-highway driving, and that EPA rating is not at 70mph. If the EPA were based on 70mph, wouldnāt the rating be somewhere between 270 and 302 (probably closer to 280 given it is a big body truck)?
Consumers should not have to help Consumer Reports correct their testing methodology and baseline assumptions.
