Powertrain Malfunction/ Reduced Power
Marc
Marc
Roswell
23 Lariat and a 25 Rivian R1S
insurance agent
I got into my truck this evening and when I put it in reverse to back out of the garage it surged and the lost power and I got a gold wrench. It states that there is a powertrain/four wheel drive fault and to contact the dealer. Has anyone experienced this before? I have 23 Lariat ER.
Shifter module.
Search the forums for your thread title and you'll see everyone who's had a problem.
jeff_h
WV
2023 F-150 Lightning XLT ER
Paint-Drying Observer
Welcome to the club!
Ford F-150 Lightning Powertrain Malfunction/ Reduced Power IMG_0179
Ford F-150 Lightning Powertrain Malfunction/ Reduced Power IMG_0153
Very likely yours is also the shifter - I swapped mine out for a rotary dial 3 weeks and 3k miles ago and bada-bing no more errors!
Adventureboy
Ouch. I'm guessing you were out of warranty? No issues for my 2023 yet (warranty for a few thousand miles still). I have the rotary shifter sitting on the shelf if/when it goes.
jeff_h
WV
It started when I had 43k miles, and I swapped it out at 49k miles. I have Ford ESP for 4yr/150k miles but chose a $200 deductible and the cost of the custom base and used rotary shifter was $160. I didn't want to have another one of the same shifters installed as I've seen posts by others that they'd gotten a replacement and encountered the issue again, so I decided it was better to go with the rotary shifter which I hope will be more reliable.
kubel
US
2024 Ford F-150 Lightning Flash (+9.6kW PPO, Max Tow)
Mine was a shifter. But if your issue is accompanied by actual power loss, it's not the shifter, it's probably a bad battery module.
Marc
Marc
Roswell
insurance agent
It ended up clearing itself up overnight. When I tried it in the morning it was fine. I did shift it quickly into reverse which caused the initial issue.
EvilUser007
2024 Flash, 2015 Model S, 2017 MS
There is a "pseudo" recall on the shifters (CSP? Customer Service Program or something like that). After a bit of negotiation I got my local dealer to swap it. Of course the parts are on back order! The "magic date" (I think) is a build date of 10/18/24. My truck's birthday is 10/10/24! After that they reportedly fixed the shifter issue.
Anyone understand why a shifter issue would cause the dreaded Powertrain Malfunction?
Ford F-150 Lightning Powertrain Malfunction/ Reduced Power IMG_1556
Marc
Marc
Roswell
insurance agent
I had this issue when I switched the vehicle into reverse real fast after just starting the truck. It reset itself the next day.
