Ford Charge Station Pro FCSP steady amber error light when plugged in.
Yes, you can ignore the DC pins, which are not used when AC charging, when checking for continuity.
Might also check the connectors on the circuit board that plug in for the J1772 control signalling.
Ford F-150 Lightning Ford Charge Station Pro FCSP steady amber error light when plugged in. control circuit plug in
By the way, you use a 5/32 Allen wrench on the "brown and blue AC Wires from charging cable" according to FCSP information documents and "torque to 70 lb-in. The brown wire terminates on the top lug, and blue to the bottom lug."
Ford F-150 Lightning Ford Charge Station Pro FCSP steady amber error light when plugged in. ccs charge cable wires
With the report of moisture inside the FCSP I'd suspect that H2O problem is more likely the cause of the failure.
Not sure if Ford checks warranty returned units for the cause of the failure or just trashes them.
But after you get a new one, probably a good idea to try to figure out how the moisture/water got in and seal it up better.
However, if it is just ambient humidity that condensed inside the FCSP, maybe relocating it to a less humid enclosed area, or using a dehumidifier, if inside a garage for example.
They are supposed to be suitable for mounting outdoors, but I wonder.
cdherman
Kansas City
RAV4 Prime, 2016 Leaf
Ford sent a message that a replacement unit is in process..
The moisture issue is troublesome. I used a USA sourced/manufactured fitting and length of flexible conduit from a local supply house for the install that was done absolutely per Ford install specs.
The box has no means for natural drainage. Many "outdoor" rated electrical boxes have drain holes at the bottom. Presumption is that some water will get in, but if allowed to drain out, no damage.
The FCSP seems to try to be perfectly sealed. Hmm.
I will install the replacement and make a point to loop back and take the cover off and examine for moisture after a hard rain or two.
Reactions: chl
Yes water getting is has been an issue for some other folks on the forum.
I wonder if the issue could be the case gasket was not aligned perfectly and/or the cover was not tightened down adequately? (see below)
Also the instructions specify the torque for mounting to the base:
Using the (4) M4 x 0.7 x 12mm Mounting Screws, attach the unit to the base securely. Tighten to 13 lb-in (1.5 N*m).
This is what they say about the cover:
Verify Gasket has not dislodged from cover groove. Run your finger around the entire gasket to
make sure there is no damage that would allow future weather to enter the enclosure.
Replace the structural cover on the unit and attach using (9) M4 x 0.7 x 6 mm screws retained when removed earlier. Tighten to 25 lb-in (2.9 N*m) using Torx Head (T20) Bit
cdherman
Kansas City
Well, they sent a new one out. My brother installed (not very difficult to swap out old for new. I will check torque setting next trip out.). Up and running.
Had a return label in the box. No one told us to return the old one, but its common sense to do so.
Return the old one, or wait till Ford asks?
I'd return it.
Reactions: chl
Returning it could allow Ford/Siemens determine what went wrong, assuming they check it, but they might/probably will just scrap it/recycle it as most cost effective.
Returning it saves you the trouble of taking it to your local electronics recycle depot.
Aminorjourney
Nikki
Internet
www.transportevolved.com
2023 F150 Lightning Lariat, 2017 Chevrolet Bolt EV, 2006 Vectrix VX-1
I just had my (counts) Fourth FCSP arrive yesterday. They all seem to give up in the summer.
Mine overheated, and Ford remote diagnosed it. A new one has been sent and arrived yesterday, but I wish Ford would work with Siemens to address the issue.
Is yours outdoors and what amperage do you use?
I read another post about someone who charged at 80A once a week or so for 2 years and what failed was the house 100A breaker.
80A continuous for several hours is a heavy load and there is no active cooling (e.g., small fan) inside the FCSP. Think about how video card and power supplies in computers have fans, and CPUs often have water cooling.
Sometimes the HIS is running 30A through the FCSP but that is probably not a big heat source.
Seems like maybe adding a small fan somehow might be a good idea and/or derating from 80A to something you can live with charge-time-wise.
If you wiring comes in through conduit on the sides (for one with an HIS that is standard) then the back opening for a wall gang box would be available for a small fan to suck hot air out of the FCSP.
Ford F-150 Lightning Ford Charge Station Pro FCSP steady amber error light when plugged in. rear gang box opening
I labeled it in the above Sunrun pic.
Just a thought.
