Low / Medium Cost Audio upgrade
Storm Breaker
Norm
F-150 Lightning Lariat
truck driver
What do you need to upgrade to the Dayton on the 8 speaker B&O? How easily does the grill cover come off. I haven’t found a video removing it. Is this the speaker? https://a.co/d/0t4ZbpT
yes. thats the speaker. the grill pulls up without too much force. there is no harness for it so i had to clip and hardwire it to the speaker. i sat it in the whole and used thick speker foam around the speaker to keep it in place with pressure. foam like this.
https://www.amazon.com/Speaker-Foam...6610&sprefix=speaker+foam,aps,104&sr=8-6&th=1
sajurcaju
Steve
2023 Lightning XLT
Is the sound notably better? I bought all of the speakers and materials, but the temps outside were getting to be a little too much. I’ll probably wait at least a couple more months at this point
I had the stock (not B&O) sound system. My objection was how bad the bass sounded, just boom boom boom with no pretense of actual notes. All the bass sounded like the same note.
I did the following, in order:
1. Block off plates front/rear from Sounds Good
This noticeably improved, but the bass is still just boom boom
2. Switched to flat response via Forscan
Again, some improvement, but no real notes.
3. Added Alpine S2 coaxials in the front only.
Now bass notes actually sound like notes. The jazz bass player sounds like their notes are from a stringed instrument, actual notes. Big improvement.
I went with front only as no one else is in the truck when I play music, and using the f/r balance the rear speakers had a very small contribution. I'm not interested in lower frequency bass, just more accurate (so no sub).
I suspect the speakers have the biggest impact, though the other changes helped.
Steve
richguy82
Richard
2023 Ford Lightning Lariat
I just saw this on Amazon. https://a.co/d/7z6O7yL. Seems to have a number of mounting points. I wonder if it would work as an adapter.
Also, someone in another forum recommended this as a wire harness for a center speaker? https://a.co/d/5ka2nI8
richguy82
Richard
Over all it does sound better. That's just my subjective opinion with no data to back it up. ;)
I just got my Lightning mid-June and don't have a lot of drive/listening time before the change. The center speaker is still off/overwhelming, so in the fade/balance I have things two "clicks" to the rear.
I didn't add any blocks or other materials. Just replaced the front and rear speakers with the Alpine R2s. Will install the center will it comes in next week and see how it changes things.
I installed mine on Tuesday when it was almost 100 here in MA. Garage was a little cooler than outside, but not by much as I had both garage doors open for light/air.
Did the volume increase after the swap or are you having to adjust the volume higher to compensate?
digitaldad
ABQ
2023 Lariat ER MaxTow
That ended up not being worth the cost & hassle...you have to cut one end off of the new harness, still splice and cut/dremel a piece of the harness off to fit in the plug when center is removed.
Ford F-150 Lightning Low / Medium Cost Audio upgrade harness
To top it off (at least in the case of the one I bought), the polarity was reversed from the new harness to the 3.5 harness...so I had to swap the spliced wires (+/-).
sstevetx
Steve
That mount adapter might make the speaker too tall causing issues with the dash grill sitting flat. There is a raised circle on the underside of the dash grille to line up with the factory speaker. I 3d printed my own mount adapter as mentioned in my earlier post in this thread and ran into this issue. My suggestion is to just get a few screws and screw it directly into the plastic near the normal mount holes. I did that initially and it was a good solution, but I overthought it and decided to try a 3d printed mount.
richguy82
Richard
I wanted to use the Dayton too, when I finally decided to puchase that and tweeters, the Dayton had went up in price and no longer available on Prime (that was week 3 of June).
The 3.5" speakers that have the little wing mounts work perfect as far as bolt placement goes but most are 4 Ohm (and also most sold in pairs). I ended up going this route and the sound is what I wanted, less volume/overpowering than OEM and still a good presence. I placed a quart ziploc bag of memory foam polyfill in lieu of a baffle...not sure if it did anything but its pretty cavernous below that area.
So you went with something different from Dayton to the mounting wings? I found this harness as a potential fit from digging in an F150 forum if anyone has experience with it. https://ebay.us/m/RD1qdW
F150Redux
Daniel
2025 F-150 Lightning Lariat
Computer Geek
I can't say the volume increased, but it does sound more "defined" for lack of a better word. Again, as I said earlier, I hadn't spent a lot of test/listening time with the default speaker, so not a lot of comparison data.
Replacing the center speaker
NOTE: I have a 2025 Lightning Lariat. The factory speaker/mount/connector look different than some of the pictures I've seen in various posts.
Today I got in the "Dayton Audio PS95-8 3-1/2" Point Source Full Range Driver 8 Ohm" (came a couple days early from Amazon via USPS) and the "iJDMTOY 18-Inch Plug-N-Play Third Brake Light Extension Cable Harness, Compatible with Jeep 2007-2018 Wrangler JK JKU". Links at end of post.
I was afraid the cable harness wouldn't work based on posts here and other sites, but that was unfounded. I just cut it in half, trimmed back about 1/4" of the wire casing, and soldered them to the Dayton 3.5" (black to smaller negative lead on the left, red to larger positive lead on the right). NOTE: Before soldering I made sure I had the right half of the harness and plugged it in temporarily just to make sure it was working.
To mount the actual speaker, I wasn't sure what I was going to do. Any mount with "wings" that looked like it would fit seem to be coming from China. And I don't have a 3D printer to print my own from thingiverse. I pinged a couple friends but haven't heard back from them yet.
I thought of chopping the factory speaker out of its mount, but didn't want to spend a bunch of time with a dremel cutting the supports/etc.
Turned out, I don't really need any kind of a mount. The Dayton Audio speaker fits perfectly in the stock hole, in fact, the alignment nubs work to center it/hold it in place. The factory 7mm screws have a washer head and there's really enough there that the two screws would hold the speaker securely in place. To give it a little extra I added some slightly bigger washers.
Tools used: trim tool to pop out speaker cover from dash (the two back/middle clips broke and fell into their holes never to be seen again), 7mm socket, wire cutter/stripper, soldering iron.
Haven't really spent any time in the truck yet since doing this. Will report back on any perceived differences when I can.
Original factory 3.5" Speaker
Ford F-150 Lightning Low / Medium Cost Audio upgrade 016
Ford F-150 Lightning Low / Medium Cost Audio upgrade 017
Dayton Audio 3.5" Speaker
Ford F-150 Lightning Low / Medium Cost Audio upgrade 018
Ford F-150 Lightning Low / Medium Cost Audio upgrade 023
Links:
https://www.amazon.com/dp/B00Q3M9852?ref=ppx_yo2ov_dt_b_fed_asin_title
https://www.amazon.com/dp/B089292V5C?ref=ppx_yo2ov_dt_b_fed_asin_title
Basis0439
2023 F150 Lightning
Links:
Fantastic, thanks. You say you used a soldering iron? For what exactly?
F150Redux
Daniel
Computer Geek
I used the soldering iron to connect the harness/adapter to the replacement center channel speaker, as shown in one of the pictures. This way I didn't have to cut the OEM wiring.
