Class Action Lawsuit - Home Integration System
Jim Lewis
San Antonio, TX
Right.
But if you do that during a grid outage the inverter is off and you're done until the grid comes back up.
OK. I didn't understand the context in which you were talking about rebooting the HIS system and wanting to shut down the Dark Start battery.
I don't think the truck going to sleep per se is the problem. I've had the truck asleep, simulated an outage plenty by cutting grid power, had the port light come on, heard relays clicking in the truck with the FCSP LED turned green, and have the white port light go out after ~30 sec with no power transfer from the truck activated. So, with my truck at least, I think a power loss can wake the system, but the communication needed for automatic power transfer is not working. If I do the UNLOCK button trick or start the truck and initiate manual power transfer, it's worked the last 4x in a row (2x via UNLOCK trick, 2x via SYNC screen manual transfer with truck running).
Steely
SE Mass
2022 Lightning Lariat
How long ago did you repair the system? Does it list the charger as Ford 3000 or the new name?
Jim Lewis
San Antonio, TX
I have the latest inverter firmware ending in .36 and after the firmware update, I did have to repair the truck and the FCSP. The FCSP is now identified in the IBP app as "Ford Charge Station Pro 1." I repaired my truck and FCSP on 6/16/25:
Pitbull2o08
Ohio
I need to make a new thread but I was able to get mine working after 70 plus emails with Ford engineering.
I would say that if your truck hasn't gotten updates you should pursue with Ford BEV hotline getting an appointment at a dealer to fix whatever is preventing that. In my case the gateway module was stuck in a state where updates were off no matter the setting shown on screen.
Confirm the inverter is up to date. There were some fixes in the newest version. I think it was version x.x.36
But most importantly and what fixed it for me was a hardware install issue. At some point they changed the installation and no longer connect the common/ground on the rs485 port. Old installs have orange landed there but this screws the transfer up and causes it to hang and eventually fail. Sunrun tech lifted this orange and it transferred properly immediately after for me.
If your having what looks like good transfer but then no power followed by failure after 1 to 2 minutes check if you have this orange communication line landed, it should not be.
I'll add in a before / wrong picture for reference.
That info was given to me over a year ago. Sunrun disconnected that orange wire. Still a no go.
v2h8484
Tesla Model 3
Not surprised that disconnecting the RS485 ground didn't work. RS485 on systems like this should really be fully isolated electrically. Otherwise it's relatively common to see comms problems due to noise or out of range common mode voltages. One potential fix is to add isolation using an external isolator. Keep in mind that you will need an external power source (e.g. a 5V or 12V battery) for the isolator.
Steely
SE Mass
Nevermind mine isn't working again. It's been 50 days since they disconnected that com wire, it worked 4 or 5 times in test shortly after, I ran it for 8 hours one test, but now after sitting it's back to the same failure mode - looks like it transferred but not actually powering the house for 90 seconds then a charger fault.
Jim Lewis
San Antonio, TX
Google Gemini and ChatGPT 5 have some very interesting things to say about this. They both agree that lifting the orange RS485 ground wire is a good idea, as it removes a shared ground between the truck and FCSP, which can be a source of problems if there's a Ground Potential Difference (GPD) in the system. But they say that removing the FCSP RS485 ground connection is likely treating a symptom, not the cause itself, a GPD problem on the FCSP/HIS side, which can come back to haunt you. I have miles of dialog shared between the two agents, along with a very detailed electrical troubleshooting guide created by ChatGPT 5, which Gemini agrees is excellent. I could provide it as an attachment or DM it to you, @Steely, if you think it might help, or you could chat with these agents directly yourself.
BTW, I notice that the orange ground is still shown as connected in the FCSP on the Sunrun field website wiring diagram instructions. Sunrun hasn't bothered updating that diagram, even if leaving the orange ground disconnected is now accepted as the better option! :rolleyes:
Actually, the orange ground wire only seems to appear in systems that have an ESS (Energy Storage System = wall battery): (upper right of following diagram)
Around 2'41" into the following Sunrun wiring verification video, it shows that the A8 RS485 connector in Steely's BEFORE picture is not wired in Home Integration Systems that only have the Lightning as a DC power source with no ESS or PV source.
tearitupsports
Russell
Cypress, TX
A ground is not needed for the serial communication. I just use 2 wires twisted together using a drill for the communications which has been flawless on my system. The EN and GRD for the lg battery is a 12v signal and has nothing to do directly with the RS485. They just happen to use the same terminal block.
Jim Lewis
San Antonio, TX
Here's what ChatGPT replied much earlier in the day as to how GPD problems in the ESS RS485 connection could indirectly affect truck/FCSP handshaking. I always mistrust AI advice from any source. I've found it can be flagrantly wrong but often it at least points me in the right general direction to a better understanding of important variables in a situation.
Yes — if the ESS ground is bonded into the FCSP, its ground potential difference can indirectly affect the truck connection, because the FCSP is the bridge point. That’s why installers saw short-term improvement by floating the ESS comm ground, but long-term reliability requires addressing the actual GPD (bonding practices, isolation, or surge/noise management).
And a further ChatGPT answer made in direct response to feeding it the first quote in this post:
Could the 12 V GRD from the ESS still cause trouble?
Yes — even though it’s “just” a logic ground, it’s still a galvanic connection between the ESS’s low-voltage domain and the FCSP’s logic ground. That means:
  • Any ground potential difference (GPD) between the ESS chassis and FCSP chassis will show up on that 12 V ground wire.
  • That offset can couple noise into the RS-485 transceiver if the board doesn’t keep the domains well isolated.
  • It won’t directly shift the RS-485 A/B voltages (they’re differential), but it can:
    • stress the isolation barrier,
    • cause common-mode noise,
    • or trip faults if the ESS logic ground drifts relative to the FCSP ground.
So the forum member is right: it’s not technically the RS-485 reference. But yes — the ESS ground still matters, because once it’s tied into the FCSP logic board, it can influence other comms and even the PLC handshake with the truck.
Jim Lewis
San Antonio, TX
In September 2025, I conducted a series of tests to determine the necessary conditions for automatic backup power transfer to function reliably with the Home Integration System. Couldn't figure it out. Manual transfer worked at least 90% of the time, except on a few occasions when I figured out a way to trigger a charge station fault, which required a cold reboot at one point to rejuvenate my system. Automatic backup power transfer actually worked a very few times. However, I'd say the manual transfer via the unplug/replug trick worked in at least 18 out of 20 tries (including two automatic transfers in the success rate).
I called the Ford BEV department today to inquire whether any further improvements are forthcoming. I was told that Ford has not abandoned the original Home Integration System, that handshake problems will be addressed in a future OTA update. Still, Ford has no estimate of when such an update will be available. ☹
Sea Ranch
Wes
CA
'22 Lighting, '24 Rav4 Prime, '19 Carrera T, '24 Transalp, 2006 Tacoma
The entire HIS debacle is sad and totally unacceptable. I have often wondered if Jim Farley has had a briefing of how well the "fix" is going after over 2 years.....
Jim Lewis
San Antonio, TX
I don't know anything really about the handshake protocol between the truck and the FCSP in initiating backup power transfer, but, at least for my system, that seems to be the problem in initiating automatic backup transfer. The unplug/replug sequence probably wakes the truck up and causes the truck and FCSP to be on the ball enough to complete backup power transfer. For whatever ChatGPT knows, it suggests that a problem in fixing the truck/FCSP interaction may be that to work with chargers in general, the truck has to adhere to a particular communication protocol (PLC?), and Ford may have problems implementing a fix within the confines of that required protocol. So, one charitable interpretation might be that they're working on a fix that gets ratified as an acceptable extension of that protocol, and committees take time to approve standards....
Zaptor
2022 Lightning Lariat ER ZAPTOR 2025 MME GT RALLY HABOOB Kubota L3560 Goats wut
.......... Trophy husband
I had such high hopes for the Home Integration System... I even bought *two* of these trucks to interface with it. I've been watching this thread from the outset, and while I appreciate everyone's efforts to get this working, I'm super disappointed in Ford's implementation and support. I had absolutely planned on buying this system (we live very remotely, and have frequent outages) but based on the experiences here, no chance...
Zap
tearitupsports
Russell
Cypress, TX
Zap
There are more options on the market now and others coming soon as well.
tearitupsports
Russell
Cypress, TX
The problem is that the truck is Ford, charger is Siemens, inverter is Delta, battery is LG, and Sunrun is the only company authorized to make them all work together. The communication is also a proprietary setup and not any sort of industry standard. I too have hope that the Ford system gets fixed (I have it) but I have much higher hopes for the newer systems to work the way the HIS was intended to.
