Jim Lewis
- First Name
- Jim
- Jan 10, 2023
- San Antonio, TX
- Honda Accord 2017; 2023 Lariat ER
- Occupation
- Retired
OK. I didn't understand the context in which you were talking about rebooting the HIS system and wanting to shut down the Dark Start battery.Right.
But if you do that during a grid outage the inverter is off and you're done until the grid comes back up.
I don't think the truck going to sleep per se is the problem. I've had the truck asleep, simulated an outage plenty by cutting grid power, had the port light come on, heard relays clicking in the truck with the FCSP LED turned green, and have the white port light go out after ~30 sec with no power transfer from the truck activated. So, with my truck at least, I think a power loss can wake the system, but the communication needed for automatic power transfer is not working. If I do the UNLOCK button trick or start the truck and initiate manual power transfer, it's worked the last 4x in a row (2x via UNLOCK trick, 2x via SYNC screen manual transfer with truck running).
