- First Name
- CHRIS
- Dec 16, 2022
- alexandria virginia
- 2023 F-150 LIGHTNING, 2012 Nissan Leaf, 2015 Toyota Prius, 2000 HD 883 Sportster
- Occupation
- Patent Atty / Electrical Engineer
Link to these tests?I can only attest to what true TESTS have shown/proven...whether you like it or not is up to you. Give it a try yourself.
There are a couple sets of 120V 20A outlets in the bed so IF you are saying using more than one of them you can get 30A that's believable.
But if you are saying ONE outlet (labeled 120V 20A 2.4kW MAX on the cover) could output 30A and a test proves that, I'd be shocked (pun intended).
It would allow you to overload a 15A or 20A cord and plug with 30A which could result in a melted cord wire/plug since they are not rated or designed for 30A, and that would be a code violation as well - yes the NEC has codes for automobile outlets:
NEC 625.60:
. Specifically addresses AC receptacle outlets used for EV power export (where the vehicle can provide power back to the grid or building). It outlines requirements for the receptacle's type, rating, overcurrent protection, and GFCI protection.
So I'm pretty sure Ford would not intentionally violate the NEC - think of the liability!
