WellingtonWorks
Hey everyone,
I’ve been chasing down an ABS issue on my 2022 F-150 Lightning and could use some input from those who’ve been through something similar.
Edit: Fixed in Post #17
Symptoms:
Code:
What I’ve Tried/Observed:
Vehicle Details:
Questions:
Thanks in advance — trying to avoid an expensive dealership visit if this turns out to be a DIY fix.
Symptoms:
- ABS warning light comes on intermittently.
- Speedometer stops working (stays at 0).
- BlueCruise/ADAS/Parking Sensors all go haywaire.
- Issue seems to happen more often at highway speeds rather than in city driving.
Code:
- DTC Codes attached.
- Forscan shows C0039 – Right Rear Wheel Speed Sensor “A” Circuit.
- Monitored live data in Forscan — wheel speed readings appear normal at lower speeds, but I haven’t been able to replicate the fault consistently on surface streets.
- Planning to do more logging during highway driving where the issue seems to appear.
- Tires are properly inflated (though I’ve considered if uneven pressure could cause this).
- Visual inspection of the rear wheel area done — looking for sensor wiring or physical damage.
Vehicle Details:
- 2022 F-150 Lightning Lariat
- Out of warranty (Carvana purchase – limited warranty expired)
Questions:
- Has anyone else had intermittent C0039 codes on their Lightning?
- Did you find it was the sensor itself, wiring, or something else?
- Any tips for catching this in Forscan while driving at highway speeds?
- Is there a common failure point or connector for the rear wheel speed sensors I should check first?
