dmd3home
- First Name
- Dan
- Apr 20, 2022
- Central Coast CA
- 2023 Lightning Pro, 2014 Spark EV, 21 Tesla Y, 2018 BMW X5 phev
I LOVE my PPO and have used it now many times to power my entire home. In fact, it is the primary reason I bought the Lightning vs a Cybertruck or Rivian. I utilize the PG&E supplied meter mounted auto transfer switch and cord to my PPO 240v outlet in the bed. It works perfectly. However, as a precaution, I always open my solar supply breakers prior to hooking up PPO. During the day, my solar is more than enough to power my entire house, but unfortunately, because my solar utilizes microinverters that require a constant power source, when the main power goes off, so does my solar....very irritating! But, the question is, if the main power goes off and I switch to PPO, can I then again close in the solar input breakers to power up the microinverters and thus my full solar power array? So now you essentially have two power sources in parallel. Because the microinverters are getting their power from the truck, the two sources will be in phase. Ideally, in theory anyway, the solar should dominate and back down the PPO which would only add power if necessary and then take over when the sun went down. The higher voltage should prevail which should be the solar. The only real issue I see is that if your loads were not adequate to use all your solar, there would be nowhere for the excess solar to go (which isn't a problem when you're connected to the grid). But, to ensure there is enough load, you could also now charge your truck at the same time! Then, the only caution would be to have enough space in your truck battery to accept the load required. Yes, it's certainly safer to just open my solar input breakers, but I just hate having 8 kW of solar just sitting there, unavailable, while I'm draining my truck battery. Has anyone tried this?
