UncleTony
Tony
2023 Lightning Lariat
Cybersecurity Engineer
I’m happy to test things out. My A/C stopped working yesterday WITHOUT power from the OBD port. I’m running it just of the USB cable and waiting for it to start up before driving.
A/C initially was working fine but yesterday morning was chilly so I manual turned off the “switch”. In the afternoon I went to use it as it had warmed up quite a bit but Now the “switch” illuminates but there is clearly no A/C.
You will need to unplug the comma until you get the coupler then if you'd like to use your AC. If you're handy with a multi meter, i can get you a breakout board and tell you which pins to ohm out.
kzoojason76
Jason
2024 F150 Lightning Flash
Did the in-lane offset not fix hugging left?
It helped it a little bit, (those are screenshots from this morning, after I sent that original post). However, now there is a slight "ping pong" effect in the lane centering. It isn't horrible at all (basically the same as Blue Cruise itself).
UncleTony
Tony
Have you tried without custom tuning profile enabled?
UncleTony
Tony
How many people would be interested in a dock integration for the Lightning coupler? You would need to be using @Ajzride's newest dock and replace the windshield side of the dock (if you already have the newest dock) in order to use it.
I already have the design completed, I just need to order it. Figured I'd gauge interest before I put in a small batch order since it doesn't make sense to order just one.
kzoojason76
Jason
Yes please!! But can I also get the original coupler when it comes in??
UncleTony
Tony
Yeah, the dock integration would be a separate product since it has to be built into the docks mounting system anyways. If there is enough interest, I can add it as an option on the ordering forums. Otherwise, I can work it out individually.
Edit for clarity - I don't have the details worked out as of yet on how they will be charged etc.. I am just trying to gauge interest so I don't order 20 and 25 people want one.
kzoojason76
Jason
Perfect!! I already have one of the original couplers on order. That can get me through while you get an order together for a “dock” version.
UncleTony
Tony
I ordered 20 since there wasn't a lot of response. After the recent changes in import laws, these will probably take a little bit to make it to me. I will post when they are available, as the import times are becoming drastically longer and I don't want to provide a false time frame.
