UncleTony
Tony
2023 Lightning Lariat
Cybersecurity Engineer
I’m happy to test things out. My A/C stopped working yesterday WITHOUT power from the OBD port. I’m running it just of the USB cable and waiting for it to start up before driving.
A/C initially was working fine but yesterday morning was chilly so I manual turned off the “switch”. In the afternoon I went to use it as it had warmed up quite a bit but Now the “switch” illuminates but there is clearly no A/C.
You will need to unplug the comma until you get the coupler then if you'd like to use your AC. If you're handy with a multi meter, i can get you a breakout board and tell you which pins to ohm out.
kzoojason76
Jason
2024 F150 Lightning Flash
Did the in-lane offset not fix hugging left?
It helped it a little bit, (those are screenshots from this morning, after I sent that original post). However, now there is a slight "ping pong" effect in the lane centering. It isn't horrible at all (basically the same as Blue Cruise itself).
UncleTony
Tony
Have you tried without custom tuning profile enabled?
UncleTony
Tony
How many people would be interested in a dock integration for the Lightning coupler? You would need to be using @Ajzride's newest dock and replace the windshield side of the dock (if you already have the newest dock) in order to use it.
I already have the design completed, I just need to order it. Figured I'd gauge interest before I put in a small batch order since it doesn't make sense to order just one.
kzoojason76
Jason
Yes please!! But can I also get the original coupler when it comes in??
UncleTony
Tony
Yeah, the dock integration would be a separate product since it has to be built into the docks mounting system anyways. If there is enough interest, I can add it as an option on the ordering forums. Otherwise, I can work it out individually.
Edit for clarity - I don't have the details worked out as of yet on how they will be charged etc.. I am just trying to gauge interest so I don't order 20 and 25 people want one.
kzoojason76
Jason
Perfect!! I already have one of the original couplers on order. That can get me through while you get an order together for a “dock” version.
UncleTony
Tony
I ordered 20 since there wasn't a lot of response. After the recent changes in import laws, these will probably take a little bit to make it to me. I will post when they are available, as the import times are becoming drastically longer and I don't want to provide a false time frame.
mmarchand
Matt
Got my coupler in the mail and installed it. The initial system faults no longer show up, which is great. But I have a lingering "Service Vehicle Soon" warning after the comma starts up. The warning does not show up right at start up, only after the comma is fully powered up. I've checked the DTCs and have cleared all from the previous errors and it's all reading as "None" but I'm still getting the service vehicle soon warning.
In the app, I get Powertrain Malfunction/Reduced Power warning on the service page but I don't have any reduced power and no other issues. Where can I look to reset this code and get the wrench/service vehicle soon off the dashboard?
Ford F-150 Lightning Comma AI self driver assistant Screenshot 2025-09-27 at 9.45.03 AM
kzoojason76
Jason
Mine is still “lost” in the mail. As soon and I get it, I can install and see if I get the same results. I can’t wait to get rid of all of the errors and warnings when starting up. Loving my Comma so far!!
B177y
Olympic Peninsula, WA
2024 Pro SSV ER Max Tow
I would try to remove the 12 volt negative for 20 minutes at this point to see if you can reset whatever module is still holding your SSN warning. It won't hurt anything and might fix it.
mmarchand
Matt
it’s only with the Comma installed. If I disconnect the USB C and start the truck, I don’t get the service vehicle soon alert on the dashboard. It’s persistent in the FordPass app though.
UncleTony
Tony
Try installing the comma with just the short USB C cable directly to the comma harness and see if the error stays.
