tearitupsports
- First Name
- Russell
- Jun 1, 2024
- Houston, TX
- 2023 F-150 Lightning Lariat ER
- Occupation
- Industrial Automation & Controls
That would be easy to do. The Sigenergy is just a CCS1 or NACS connection. It can be removed and you could use the mobile charger or a wall charger every once and a while for AC. It would be a much more elegant solution than the pro power inverter (which can only be used as an off-grid generator input on these types of systems).It will work with any charger, but for the OEM BMS to balance the cells it has to be periodically charged with the OEM on board AC charger exclusively.
