milleniumfalcon
- Sep 9, 2025
- Ontario, Canada
- F150 Lightning Pro, SR Battery
I currently have a 2022 Lightning Pro with the SR (standard range) battery. I'm very happy with the vehicle but have found the SR battery slightly limiting.
I've been given two extra (loose, detached from truck) ER (extended range) batteries. I am trying to decide what to do (if anything) with these spare batteries. They could be cannibalized for modules in another lightning battery, cannibalized for stationary use with a solar array, or installed as a full pack in an ER truck.
I am considering buying a used ER truck, ideally at a discount due to high mileage, on the theory that I have a replacement battery on the shelf waiting. I don't know if this is a good idea. Ideally I'd find a truck that needs a replacement battery immediately and is priced correspondingly, but most are still under warranty so this seems unlikely.
My theory is that the batteries are the high-value part likely to need replacing first. Aluminum body should be good for a long time, motors good for a long time, suspension and steering repairs relatively inexpensive. Wiring/charging problems unknown but hopefully not too expensive to repair if required. Please let me know if you disagree.
What are we expecting to see for lifespan mileage of these batteries? I'm currently driving around 40k km per year and am guessing a utilized battery would be ready for replacement around the 250k km mark. That's an un-informed guess (250k km lifespan) I've been using when thinking about storing a spare battery for several years on a shelf. What do you think about the expected battery lifespan? Mostly Level 2 AC charging at home. I'm thinking I could take an ER lightning to >500k km on two batteries (one original, one replacement) without major repairs (assuming no accidents).
Maybe I'm being pessimistic about the battery lifespan, and we're all going to get 400k km on our batteries without serious range degradation - I'm not particularly informed on this topic and made up the 250k km estimate.
What do we think the battery market is going to look like in five years? In ten years? There's little point planning around OEM batteries if we think after-market batteries are going to be plentiful/cheap/better. My working assumption is that I'd drive the truck a fair bit and be ready to swap batteries in <5 years, and that at this point the technology won't have changed enough for the free spare OEM battery not to be attractive. This assumes I buy a relatively high-mileage truck and the battery lifespan isn't exceptional.
What do we think will happen to a battery stored on a shelf for 5 years? Any ideas for how to maintain battery health over this period? I'm realizing I may need/want to keep the battery from freezing.
Questions that are maybe more appropriate for the dealership:
Does anyone know if it's possible to test battery health detached from the vehicle? I can call the dealership. No point planning around batteries that are in poor health.
Does anyone know about battery compatibility between model years? One of the batteries has a 2023 stamp with 143.4kWh marked.
Thanks for any advice you're able to share.
