Hack for lowering spare tire?
jallen
2009 F150 XLT / 2023 Ford Lightning Pro
UPDATE: Please see my reply a few posts down!!! I may have jumped the gun…sort of!
Ok, so I’ve owned multiple F150s since 2006, and maybe I’m slow, but I never knew this hack before today.
I’ve always lowered the spare on occasion to keep the mechanism free and check the condition of the tire, but now with my Lightning I do it every rotation and incorporate it into the process and then put it back away. This allows me to jack one wheel at a time, which is easier with the lightning.
We all know getting the jack kit out and then put away correctly is a pain. Turns out the tool is the same diameter as a 3/8” socket! So, I cobbled together all of my extensions, and then chucked them up backwards in my drill, ran it in reverse, and Wahlah!!!!!
So much faster and easier than getting that stupid jack kit out!
Sorry if this is an already well known fact!
Ford F-150 Lightning Hack for lowering spare tire? IMG_4513
Ford F-150 Lightning Hack for lowering spare tire? IMG_4514
Ford F-150 Lightning Hack for lowering spare tire? IMG_4515
Ford F-150 Lightning Hack for lowering spare tire? IMG_4512
Athrun88
Toronto, Ontario, Canada
Great tip, especially for new owners! What's the rough length of the extensions combined? I haven't taken out the jack set yet myself.
sd25
NJ
2022 F-150 Lightning Lariat ER, Rivian R1T
Great idea! Thanks!
I guess now I'll have to my OEM 'jack kit' back in my truck : /
I replaced it with a more robust JACK LIFT, and 4-way foldable lug wrench, which is much, much better and easier for ANy vehicle, ESPECIALLY this high-stance truck frame... oh well...
I guess I forgot all about how to 'get to' the extra tire : )
Ford F-150 Lightning Hack for lowering spare tire? 1728164137147-2z
Ford F-150 Lightning Hack for lowering spare tire? 1728164212792-f6
jallen
Well, stand by everyone!!! Sorry for misinformation!!! My particular 3/8” that ended up on the end grabbed just fine…but the others I have do not!!!
Turns out it is 0.5” needed. So it’s closer to your 1/2” extension, not the 3/8”!
Did same thing with my 1/2” extensions and it works much better without slipping.
My particular 3/8” extension lowered it just fine, but slipped when cranking it back up!
I measure the post…it is tapered which explains why it works with multiple sizes. If you use a 3/8” , you need to maintain force towards pin so it does not slip, since it’s tapered. See photos.
Ended up removing the plastic “funnel” so that I can use the 1/2” more easily.
Sorry for the confusion!
Ford F-150 Lightning Hack for lowering spare tire? IMG_4523
Ford F-150 Lightning Hack for lowering spare tire? IMG_4519
Ford F-150 Lightning Hack for lowering spare tire? IMG_4518
Ford F-150 Lightning Hack for lowering spare tire? IMG_4525
Ford F-150 Lightning Hack for lowering spare tire? IMG_4524
I just got out my 'old' OEM jack set and removed the two 'longer' bars, connecting them, and then 'finding' the way into the funnel 'tunnel', after removing my 'key locked' door/opening.
I found that the supplied lug wrench provides a proper leverage on the end to easily turn the bars, and lower the wheel/tire. I found that it was just as easy when turning it back right to raise the wheel/tire.
I then put these three bar/parts under the rear seats for the 'next' time I need them.
I will probably forget these 'hidden' tools, and wonder 'how in the heck' to get that spare tire down when the time ever comes : / oh well.
Ricks Lightning
Rick
Los Angeles
Plumbing Contractor
An 8 point socket works on square nuts or in this case a square shaft.
Might need to put the socket on after the extension is pushed through the bumper.
Rick
sstevetx
Steve
Tried out this morning and it worked. I lubricated the winch and reeled it back up. I wasn't sure if the cordless drill tightened it enough, so I tried the stock tool. I was able to tighten it more several spins. I lubricated the key lock as well. Nice little trick to do regular maintenance.
Call AAA.
We got a flat on the highway, I10 just outside of Benson heading towards Tucson. My wife called AAA while I started figuring out how to get the spare down ( had no clue, first time F150 owner ). Despite that delay, I still had the spare pumped back up to the correct PSI and on the truck tightening the lugs when the tow truck driver called to get our location. Would've been about 30-45 min wait for AAA beyond what it took for me to just do it. And now that I know how it all works, I could do it in half the time it took me.
flabrent
Brent
Florida Panhandle
'25 Ford Lightning Flash Job 2
I've searched the internet, and this forum, for the jack and factory tool to lower the spare to no avail.
My Flash didn't come with a spare and I didn't think it would be hard to find everything needed for a useful spare. The tire and rim, no problem. The jack and tools to lower the spare are another story.
If someone could share a part number or link it would be very much appreciated.
SpaceEVDriver
Arizona
I use a hex shank socket adapter, an 18” hex shank extension, and a 13 mm 8-point or 14 mm 6-point socket. To avoid the the socket coming off inside the plastic receiver tube, I sometimes use the short part of the jack kit to turn the crank.
Ford F-150 Lightning Hack for lowering spare tire? PXL_20251012_000248094.RAW-01.COVER
Ford F-150 Lightning Hack for lowering spare tire? Screenshot 2025-10-11 at 17.10.33
flabrent
Brent
Florida Panhandle
Wow! I've been purchasing from them over 10 years with no issue.
Of the pictured items on their site, they shipped only the jack, item #3. They are claiming that the jack tools, tire tools, and carrying pouch are not included, items 2, 5, 6, & 7.
So I'm going to ship the jack back and see if they issue a refund.
I'll give them a couple more weeks, on top of the two weeks I've already been dealing with them, but I have a feeling I'll end up disputing the charges with AMEX.
