WaterboyNorCal
Erik
NorCal
2023 Ford Lightning XLT SR
Nunya business ;)
Just in case anyone with 18” wheels (XLT or PRO standard wheels) wants a slightly bigger AT tire with a higher sidewall. My preference is a smaller wheel and larger sidewall; I just personally find it to be a bit weird that so many OEMs are putting 21/22” wheels with narrow sidewalls on trucks as standard equipment. People must like that look and less compliance, I have no idea.🤷‍♂️
Ford F-150 Lightning New LT tires- 275/70/R18 Cooper Discoverer AT3x IMG_0202
Ford F-150 Lightning New LT tires- 275/70/R18 Cooper Discoverer AT3x IMG_0205
WXman
Central Kentucky
2025 F-150 Lightning Flash
Meteorology/Transportation
I agree 100%. I also prefer less wheel and more tire. The benefits of more tire are numerous. I wish mine came with the 18s.
Your truck looks great!
ClevelandBeemer
If you’re driving is primarily on asphalt, then the 20” wheels still have a TON of sidewall. Here’s what low profile truly looks like….
Ford F-150 Lightning New LT tires- 275/70/R18 Cooper Discoverer AT3x IMG_2719
WaterboyNorCal
WaterboyNorCal
Erik
NorCal
Nunya business ;)
True- the stock Lightning 275/60R20 tires are not “low profile” but they are still narrower than tire/wheel combinations that truck manufacturers have used in the past. For example, the standard tire on a Rivian R1T is a 275/50R22, which is relatively narrow for a traditional truck tire (and I believe it’s either standard on the Platinum trim or an optional size???). It’s certainly not a tricked-out low rider but it does lead to a rougher ride and (at least to me) looks kind of funny. But maybe I am just getting old, haha. When the ratio between wheel and tire gets that narrow, all I see is the rim, and the rubber looks like an afterthought. I expect to see that on an M3 or 911 Turbo. Just not sure about why it makes any sense on a truck, from a usability standpoint.
Ford F-150 Lightning New LT tires- 275/70/R18 Cooper Discoverer AT3x IMG_0206
ClevelandBeemer
For example, the standard tire on a Rivian R1T is a 275/50R22, which is relatively narrow for a traditional truck tire…. I expect to see that on an M3 or 911 Turbo.
To be fair the Rivian is more of a lifestyle truck, much like a G63 AMG. Ironically both Rivian and Mercedes have AT wheel and tire options for those that want them.
BTW I do know a thing or two about Turbo S and M car wheel and tire choices. They’re not too bad. It’s the lower trims that usually go too far with the low profile tires.
Ford F-150 Lightning New LT tires- 275/70/R18 Cooper Discoverer AT3x IMG_4054
WaterboyNorCal
WaterboyNorCal
Erik
NorCal
Nunya business ;)
Nice garage! I’m not dissing lower-profile street tires, I just think that they’re a strange choice for a truck. If I didn’t say it earlier, “to each their own.” 😎
ClevelandBeemer
Oh I didn’t think you were throwing shade at all. Just funny that your mentioned those two cars. 😉
jberg150
Justin
CT
23 lightning xlt
Looks good. Any issue with the tires rubbing?
GunRack
Peter
Seattle, WA
22' Lighting XLT
hows the road noise compared to stock? Mine is running on original 2022s so thinking its about time to change them out.
WaterboyNorCal
WaterboyNorCal
Erik
NorCal
Nunya business ;)
None at all. These tires are just 1/10” larger than the stock tire/wheel combination on the Platinum trim.
WaterboyNorCal
WaterboyNorCal
Erik
NorCal
Nunya business ;)
compared to stock, maybe just a little bit louder? I had the Michelin stock tires and they honestly don’t sound much different. But yeah, probably louder due to the deeper tread and more aggressive sidewalls. I don’t drive much with my windows open so I can’t hear a thing from inside the truck. The other Cooper Discoverer AT3s that I have run were pretty quiet, though, for an AT tire.
Granger Ford
Gold Sponsor
Zach
Granger, IA
www.grangerford.com
Principal at Granger Motors
Looks sharp! Ready for anything!
Randall Stephens
Seattle
2023 F150 Lightning Lariat ER
Jet Builder
You f*cking idiot! It’s a privilege to feel every pea sized rock under the tires with the big rims :D
Ishkatan
Adam
Monrovia, Md
2023 F150 Lightning Lariat ER =RAe (Range Anxiety)
Old
I thought the larger wheel / smaller sidewall give better mpg kw/hr than smaller rim larger tire combinations. As YouTube talking heads said, the angular momentum of larger and heavier tires reduces mpg, especially on highways. I suspect the additional flexing of the large sidewall also makes a difference.
When I see an F150 Lightning on Fiat sized tires I will know the guy is trying to stretch his range to the maximum..
WaterboyNorCal
WaterboyNorCal
Erik
NorCal
Nunya business ;)
I think there are a few different things getting mixed in here. Yes, heavier tires/wheels should lower efficiency, due to the increased force it takes to rotate the additional mass. But a smaller wheel matched with a tire with a ‘taller’ sidewall shouldn’t affect efficiency in a negative way, assuming no changes in aerodynamics/rolling resistance, and yes, assuming the sidewall is stiff enough.
If larger sidewall tires mounted on smaller wheels decreased efficiency, why does Tesla offer smaller wheels with their highest range models, and when you “upgrade” to larger wheels & tires with a shorter sidewall, the estimated range always drops?
