‼️ UPDATE FORD E-RAPTOR grille swap and install tutorial
digitaldad
ABQ
2023 Lariat ER MaxTow
Next I have to align my light bar
Did you ever attempt this?
Open frunk, turn passenger side bump stop clockwise a few full turns and driver side, a few counter-clockwise half turns (based on what I'm seeing in pics).
Close frunk, inspect, then open, rinse and repeat with half-turns until horizontal alignment satisfies.
When I did this, I also saw more uniform hood to fender lines on top edges of each side.
Telemachus
Lightning
Close trunk, inspect, then open, rinse and repeat with half-turns until horizontal alignment satisfies.
Any pics you could share? I have no idea what you're referring to and want to try it.
digitaldad
ABQ
Grabbed a snapshot on that YT guy that removes his frunk tub. This is the passenger side, of course (you do not need to remove the plastic access liners/clips to do this).
May have to use channellocks for first turn but can then do by hand.
Clockwise = lowers
Counter-clockwise = raises
Ford F-150 Lightning ‼️ UPDATE FORD E-RAPTOR grille swap and install tutorial Screenshot 2025-10-03 073920
Found a driver-side view with liners/clips still in place.
Ford F-150 Lightning ‼️ UPDATE FORD E-RAPTOR grille swap and install tutorial Screenshot 2025-10-03 074708
Clockwise = lowers
Those adjusters align the hood to the fenders, not necessarily the light bar. Check to make sure your hood is even with the fenders if you adjusted those.
If the hood is already aligned one needs to align the light bar by itself.
Telemachus
Lightning
Ok, so how?
Telemachus
Lightning
That would have been great to take care of when I had my grill off. It's not happening now. Mainly just because getting the plastic clips off inside or such a pain in the rear end
digitaldad
ABQ
Yep...I stated in my post (one before what you quoted), this aligned the hood and the light bar.
Telemachus
Lightning
My hood is lined up to the fenders. The light bar is lined up to the hood. The problem is my passenger side headlight is about a quarter inch too low.
Ford F-150 Lightning ‼️ UPDATE FORD E-RAPTOR grille swap and install tutorial 20251003_092056
Ford F-150 Lightning ‼️ UPDATE FORD E-RAPTOR grille swap and install tutorial 20251003_092103
DocFox
Justin
Missouri
2023 Ford F150 Lightning Platinum
I did mount the camera and grill today. And the bottom of the hexagon needs to be trimmed, and more than I thought.
Keeping the original angle of the camera, and cutting only one hexagon, will limit the viewing angle achievable because the body of the camera hits the grill itself. I will trim some more tomorrow and see if its acceptable.
Were you able to get your 3D-printed "hexagon replacement" to work?
hb.sagen
Henning
Norway
F150 Lightning 2023 Lariat
I use my latest version, but its not perfect. No mount will enable the camera to give perfect view without removing at least two hexagons. One corner of the base of the camera needs to be outside the grill to maintain the original angle.
The result with my current mount is that the image is boxed by the hexagon, even after I removed the bottom of said hexagon.
I only use my front camera to park close to things, and I don’t park that way often, I back into spaces. And the cameras from the mirrors cover a good portion of the front corners.
The next iteration will be to remove two hexagons, and hide the corner of the base of the camera in the top one, and make a cover for it, and then have the camera head poking down in the lower hexagon through the mount. Could possibly be one printed part.
I have seen some installations that ignores the original angle, and have only a round hole with the camera pointing nearly straight out. It looks nice, but unless any calibration fixes that, the view would be way off.
Fistandantilus
Germany
2023 F150 Lightning Platinum
Hi, I am following this thread since a while and now also ordered the new grille. Not that easy in Germany as most shops only sell or ship to US btw. Finally made it using Alibaba for a good price - 230 USD. Tax and customs still be on top, but should be still below 300 USD which is good. But that just as a side note.
Did anybody think of replacing the cam itself with some aftermarket cam or one from any other brand if possible?
Telemachus
Lightning
There really is no need to. One small hole through the grill is all you need.
Fistandantilus
Germany
But you have to deal with the different angle. Does anybody have a picture with the changed angle? I still would like to see the bumper for parking as close as possible in some areas.
Telemachus
Lightning
I don't think I could ever see the bumper...
Ford F-150 Lightning ‼️ UPDATE FORD E-RAPTOR grille swap and install tutorial 1000028309
Ford F-150 Lightning ‼️ UPDATE FORD E-RAPTOR grille swap and install tutorial 1000028311
Ford F-150 Lightning ‼️ UPDATE FORD E-RAPTOR grille swap and install tutorial 1000028310
Ford F-150 Lightning ‼️ UPDATE FORD E-RAPTOR grille swap and install tutorial 20251023_115717
