FPL Evolution Home - Mounting Charger Outside
026TB4U
2024 Avalanche Lightning Lariat ER
Hi all,
Everything I've read so far about FPL Home Charger installation says inside the garage.
I would like to mount it outside to an existing box. Has anyone had FPL install their charger outside?
Thanks.
Going off their literature, no, it's inside an attached garage only.
Probably cheapo indoor only evse.
026TB4U
They use a Wallbox Pulsar Plus which is outdoor rated, so not sure why they are only saying indoor installations.
026TB4U
Maybe there is a chance they'll do it.
Ford F-150 Lightning FPL Evolution Home - Mounting Charger Outside Screenshot_20251016-131601~2
MikeLang4d
Michael
2025 Ford Lightning Lariat
I had the Ford charger installed outside of my garage and then had FPL replace it with their Wallbox charger. It works great and I’m getting the full 48 amps.
026TB4U
Great. Thank you for confirming. Interesting that you are getting 48 amps. The website says 40 amps maximum.
What size breaker did you have and what did FPL use?
Thanks.
MikeLang4d
Michael
Thanks.
It’s on a 60 amp breaker. I too was surprised by the 48 amps because I was expecting 40 amps from everything I had read.
RdWarriorRuss
Russ
Navarre, FL
F-150 Lightning Flash
Field Sales
80% rule is that the breaker needs to be sized 20% higher than the running current. Therefore, you can only charge a maximum of 48A.m in a 60A breaker. 80A on a 100A breaker, etc.
026TB4U
Update. FPL will let you mount their charger outside if you already had one outside. I didn't see this as an option with their full install. With the full install option, they say it has to be installed inside the garage and 10 feet from the breaker box.
Even with the EV ready option, where you have a box, they don't say it can be mounted outside until after you enroll and start answering some questions.
With that done, they have now asked me send them a screenshot with a wifi analyzer at the charger location outside. They want to see a reading that is consistently below -64.
One thing I have questioned is that they are requesting a disconnect box within 10 feet of the charger location. I read in several places that this is only needed above 60 amps, and since this is 60 amps, it is not necessary. I am waiting for a response on this.
026TB4U
Another update. FPL insisted I install a disconnect box so my electrician did and asked why "didn't they tell you it was needed from the start"? Good question.
Then the electrical company doing the install for FPL says "did FPL ask you to put in a disconnect"? I said yes and he proceeds to tell me that they have told FPL it's not required and that t-handle disconnects have melted on some install and they are not recommend.
So he tells me I don't even need a box and installed it going into the rear of the unit. Cleaner install and actually what I preferred.
So it is installed and works great. Since I used a 60 amp breaker, it does charge at 48 (47) amps although FPL said it is charges at 40.
Ford F-150 Lightning FPL Evolution Home - Mounting Charger Outside 1000017614
Ford F-150 Lightning FPL Evolution Home - Mounting Charger Outside 1000017617
