Ford App update is terrible
CNYLightning
Ben
2023 XLT Lightning
Recently I have been getting a charge error message in the app while charging. The truck keeps charging so I think it’s in error. Not sure but I think it started happening after the app update. Anyone else experiencing this?
KSkel
Keith
DoD
Same, happens around 1.5hrs of charging
3rdgenfan
Geoff
Delaware
Cybersecurity
I haven't been able to get the remote climate to work via the app since the update on my Pixel, nor did it save the 90% charge limit at home.
Rather annoying.
flabrent
Brent
Florida Panhandle
'25 Ford Lightning Flash Job 2
Some insurers do utilize data from mobile phone apps or features, so it's important to understand your insurer's practices and read the data and privacy agreements for apps you load onto your phone.
And that's why I keep an old Samsung Galaxy S9 in the kitchen drawer. When T- Mobile, Kasa smart plugs, Alexa, whatever, requires an app to do something, it gets installed on the sim-less (Wi-Fi only) S9.
Ford Motor Company
Official Ford Account
F-150 Lightning
Brian Siggy
Connecticut
2025 Ford F150 Lightning Lariat
Same here, but mine is NOT charging when the error message happens. I have an Emporia 48A charger at home. I called Ford this morning and they say this is not happening to others that they know of. Also, they said that I should remove the Preffered Charging times and Departure times. I had already done that from reading things online and Copilot said this, but it doesn't make a difference. I even deleted Ford App and reinstalled, reconnected my truck and created a new Key. Same problem. Some times 45 minutes, but lately it's within 15 minutes that it stops charging with the error.
Flash2025
Federico
Houston, TX
F150 2025 Lightning Flash
I'll get you an answer. Sit tight.
terrible terrible update, the update destroyed the amazing app, it takes seconds to open and update vehicles status, I do have 3 EV and is the same poc with all of them, you shouldn’t never update the previous version, I guess stupidity is at all levels in Ford.
ScottC
Scott
2024 Ford F-150 Flash
What are your issues with it? The ford guy, Brian, has been saying he is relaying feedback to Ford.
my issue is that the past versions worked well for my needs. Two homes w chargers, and specific charge timings set up.
when I launch the app, i want to know my current charge level and, if plugged in, when will the charge start. From there you decide if you need to do more in the app.
I’ve driven EVs since 2016 and this is a first. Hopefully a quick fix.
Ford F-150 Lightning Ford App update is terrible IMG_9634
Ford F-150 Lightning Ford App update is terrible IMG_4060
JTWIRE55
Manheim Pa.
2023 Lightning Platinum, 2026 Tesla Model X, 2022 Mach-E
The app needs improvement, the Tesla app far exceeds this one in all categories
bewbie
NYC
Anyone have any issues with remote start from the app (which is the only way considering the key fob doesn’t have that button apparently).
I downloaded the update and tried to use remote start and it would just spin a little circle and then revert back to the last time. The truck would not start, but it has started on some instances so it is very very spotty. I’ve tried downloading the app again and re-installing iOS
MrZap
Toronto
2022 F150 Lightning Lariat SR
My success rate since app update is less than 10%. With the old app I was probably at least 90%.
Any insight anyone?
RLXXI
3rd rock
Automotive Technician
Any insight anyone?
Bought a fob for a 25 ice f 150 and programmed it as per the manual and it works perfect but you lose remote frunk, it does have remote tailgate but I have no way of testing, don't have it on my truck.
Ford F-150 Lightning Ford App update is terrible 54959670337_c0231b0694_z
