LazyLightningATX
Doug
Austin
'23 Lariat ER
is 6.1 going to unbreak PAAK? i sure hope so! guess ill find out later.
i bet it only has worked 20-25% of the time since i got 6.0. i have to get my phone out and open the app almost every time in the parking garage at work and the app acts like it is opening fresh, so it is obviously crashing in the background or something.
it was probably up there around 90% success before.
3rdgenfan
Geoff
Delaware
Cybersecurity
Interesting, I did not have any problem with start climate with 6.0.0.
It's been hit or miss for some time now, and got better in the last FordPass 5.x update but has yet to work after going to 6.0. Doesn't save my targe charge setting at home and will just give me a yield/error sign after the climate attempt times out.
Jesse-Infotainment
2024 F150 Lightning Platinum
I have Pro Power showing now. 6.1/iOS 26.1(Non Beta)
Ford F-150 Lightning Ford app v6.0.0/6.1.0 FKA Ford Pass, IOS & Android IMG_2514
PJnc284
Garner, NC
They'll probably make me wait just because I enabled PPO while off. :cwl:
Rice_classic
Rice
2023 F150 lightning lariat ER
The previous version of the App had a place to show if any recalls were out on the truck but I cannot find anything regarding recalls in the app now.
Was it removed or can someone tell me where to look (in the app).
PJnc284
Garner, NC
It shows under the wrench in mine (same screen that shows tire pressure). Have to scroll down
Rice_classic
Rice
Not for me. On that a screen I have:
Service Schedule with maintenance, service and alert (none of which show recalls).
Below that is preferred dealer, then emergency services and then reference. None of which get me to recalls.
K6CCC
Glendora, Calif.
This is what I have:
Ford F-150 Lightning Ford app v6.0.0/6.1.0 FKA Ford Pass, IOS & Android Screenshot_20251104-104534
The active recall is the Upper Ball Joint and the CSP is the Gear Shift Module replacement. Dealer is waiting for the replacement GSM and then he'll do both.
The Weatherman
Dean
South Central KY
Are you Android or IOS? I’m iOS and don’t have the recall / CSP’s showing even though I have two open Recalls.
K6CCC
Glendora, Calif.
I'm team Android. I had a work forced on me #$%^& iPhone that I absolutely despised, but happily gave it back when I retired a month ago :)
