Ford App 6.6.0 iOS & Android
The Weatherman
The Weatherman
Dean
South Central KY
Mine wiped out my preferred charging settings and schedule. Did anyone else have that happen? I got a truck update at the same time (first one in months) so I’m not sure which one caused it but it appears to have happened before the truck update was applied.
The truck updates has been known for that behavior.
astrand1
Alex
Studio truck driver
Does the update immediately kill PAAK? Not good if the app updates while you are away from home and don't have a physical key.
Nope. Not for me. Still works as it should.
Tony Burgh
Tony
Western Pennsylvania
22 Lariat ER
It got mine too. My times were set to match super off peak night time rates and max SOC of 90%. There are notes telling me to AC charge to set location then I can fix times and max. I will charge tomorrow (Saturday) at off peak to initialize.
jobofly79
Joe
2024 Ford Lightning Flash 312A
This section is new to me. Anyone else just get these options?
Ford F-150 Lightning Ford App 6.6.0 iOS & Android IMG_0205
The Energy help section is not on my older 6.5.0, I guess that is an improvement, what happens when you tap the label, or is there more information below the section ?
Ford F-150 Lightning Ford App 6.6.0 iOS & Android 1770482182461-0g
Rip
Rip
Southwest Harbor, ME
2024 Lightning Platinum
Quality Consultant
I kind of wish they would not just say, "Minor Bug Fixes." What minor bugs? What will be different?
K6CCC
Glendora, Calif.
I just checked and 6.6.0 was available for my Android. Updated without issue. My preferred charge times and limits are still as they were. I do not have the Charge Help option at all.
roddiaz1
Rod
Pittsburgh
Updated the Ford Pass App the other day and the truck got an update that same night (Charging Port Lock) and somehow all my Ford Pass App settings were deleted and I had to start all over again with new charge locations and charge limits, departure times, and charge times, etc.
Slightly annoying! Anybody else?
21st Century Truck
Martin
I just got FP 6.6.0 on my Android. The new improved charge settings are on it, as per posts #19 and #21. My TOU charging times are unaffected. I don't use PAAK, so "no comment" on that.
Received V6.6.0 {ANDROID} this afternoon, this install fixed my view of the service tab for up coming maintenance reminders and open recalls, though like many the Park-Pawl issue is not showing but I can now see the tailgate light bar issue.
Also I did a mid-week charge this afternoon, the rules previously set are working fine, (unlimited time frame & maximum SOC = 90) worked perfectly.
Ford F-150 Lightning Ford App 6.6.0 iOS & Android 1770776603317-z
abcut973
Anthony
Denham Springs
Just realized 6.6 is available for my android.
I do not have the "energy help" option. It also fixed my service tab view.
I can see the Pro Power Onboard information on the main vehicle tab.
Ford F-150 Lightning Ford App 6.6.0 iOS & Android 1770780278932-ri
Ford F-150 Lightning Ford App 6.6.0 iOS & Android 1770780298767-ei
