K6CCC
- First Name
- Jim
- Sep 12, 2024
- Glendora, Calif.
- 2024 Lightning Flash ER in Antimatter Blue w/9.6 PPO , 2017 Corolla (wife's car)
- Occupation
- Retired from 2-Way radio systems
Well, this is interesting. Shortly after I posted the message above, I went out to the truck, got in, and brought up CarScanner. Note that the truck is in Silent Mode so no lights were on. I did not turn on the truck. It was showing a 12 amp load on the 12V battery which changed to a 6 amp load a minute or two later. Voltage was just over 12 volts. Turned on the truck and immediately saw the voltage climb to over 14 volts and charging current to 60 amps. The current tapered off fairly quickly. Used CarScanner to read DTC codes and saved them. It's a long report so I'm not going to post it here, but it can be read in it's entirety at: http://k6ccc.org/DTC_2025-11-29.txt
Below are screen captures of the CarScanner LVB page through this. You can see the time from my phone at the top of each image
